Indicator Problems
Started by piper alpha, March 17, 2010, 06:47:11 PM
piper alpha
Just a minor problem, the left indicator wont work unless I quickly flick the switch from right to left? I was thinking the switch it's self, if anyone knows what it could be I would be grateful... Thanks
Oh, I forgot to mention, although I'm not sure if it's related to the indicator problem but my horn won't work either?
Quote from: piper alpha on March 17, 2010, 06:47:11 PM
Could be something as simple as dirt in the switchblock.  I'd start there and remove it from the bar, and carefully dis-assemble it cleaning as you go.  You can get electical contact cleaner at most electronics parts stores.
Are all your globes working?  Is the flasher relay unit working?
If not that, then you may have to trace the wiring to find a break.
Also, don't forget to check the fuse (duh), I've spent hours checking before when the fuse was toasted.
piper alpha
Quote from: Arnie on March 17, 2010, 08:10:00 PM
Hi Arnie, All bulbs and fuses are working fine. As I said, If I quickly flick it from right to left, It will work? I'll have a good look and see if there is something I can do. Thanks for your reply. John
