Chain slider
Started by aj52, January 12, 2017, 09:03:32 PM
aj52
Hi guys
My chain slider on swing arm are in pieces.
I know Randy has for the '92,but expensive cause of exchange rate.
What I want to know is if Teflon will work to manufacture one?
Hannes
1991 FJ 1200 ABS
1991 FJ 1200
Davo231481
Or chop your wife's cutting board and fit it with non acetic silastic such as marine grade such as silastic. I measure the width of swing arm and made a two piece. Cost $0 if you don't get caught by the missus. I driven for a couple of tanks since fitting and it works well.
balky1
Quote from: Davo231481 on January 16, 2017, 03:52:49 AM
Wooden or plastic cutting board?  :crazy:
FJ 1100, 1985, sold
FJR 1300, 2009
Davo231481
Nylon.......I used the wooden one for new brake pads
ct7088
3M AC TECH CLASS B FUEL TANK AND FUSELAGE SEALANT AC-240 (QUICK CURE / 1/2 HOUR)     https://www.aircraftspruce.com/pages/ap/seal/ac240.php
This stuff will hold the pieces in place. $54 a pint
Chris
aj52
Done about 1000km on the new chain slider.
The teflon seem to work well so far.
Here is some photo's.
1991 FJ 1200 ABS
1991 FJ 1200
Looks top notch.  :drinks:
Please let us know how the wear characteristics work out.
