Upside Down Winter Project
Started by aviationfred, December 22, 2016, 08:32:30 AM
Christmas is almost here and my Winter project is about to kick off. Parts are beginning to arrive. I have yet to receive the Rotors, carbon fiber fender and handle bars. The Rotor bolts are Titanium
axiom-r
Believe me when I say you are going to LOVE what that new front end does for your FJ....  Especially the brakes...
Congrats!  Enjoy the process!
Tim
Quote from: axiom-r on December 22, 2016, 09:51:21 AM
Tim
+1
Hey Fred I used spiegler for the brake and clutch lines. They're adjustable for the orientation of the banjo fittings. I had a local shop that does hydraulic lines make up the first set. But he had to redo them because the banjo fittings were not quite right..
I used the stock line that crosses over the fender between the calipers.
The gsxr upper triple clamp has the Lock offset. And it's a little too close to the frame. I used a sanding drum. That you attach to a drill (I think it was a 2" been awhile) to remove just enough from the lock for clearance. And you will have to remove the tab off the one side of the frame where the lock goes . All small things that I had to figure out. I made  new steering stop tabs and welded them to the frames. On the first 2. Because the gsxr stops are at a different place on the lower triple clamp. But I was thinking of trying to relocate the tabs on the triple instead. The aftermarket triple clamps use aluminum tubes bolted to the lower for the stops.
My.machinst has been going to make me upper triple clamp that has the Lock in the center, offset correctly for the Fj. With the correct sized hole for the stem. To eliminate the sleeve/spacer. But he just hasn't gotten a round to it. I should give him a call. I need 3 of them. For my bikes.
   Very cool Fred, are you going the gps route for the speedo?
I'm planning a YZF750 USD upgrade (external adjustable rebound and compression) can you give me a link to your handlebars?
Thanks!
Quote from: Pat Conlon on December 23, 2016, 01:06:11 PM
Thanks!
I think Fred already has those really cool speedhut guages? That are gps?
I have a digital speedo that runs off the front wheel. I drilled out a brake disc bolt and epoxied the magnet into it.
I am interested in those bars too. Wondering how well they are going to work. I have Apex bars. More adjustable. But more expensive. And the design of them. If I rotate them around the front to get them narrower. It brings them forward. The ones I made to match the stock Fj bars are the best. Imagine that, Yamaha having the best design for the bike. But the ones Fred found seem like they might be narrower than the Apex. Can't wait to see how they work.
You do nice work Dan :good2:
My bar clamps are going to be below the top triple clamp, so I'm concerned about the clearance with the inner fairing panels.
I was considering the Spiegler set up:
https://spieglerusa.com/controls/handlebars-accessories-236/multiclip-tour-50mm.htm
Not sure they will clear...
jscgdunn
Pat,
Watch the tank clearance at full lock as well.
Merry xmas,
Jeff
90 FJ 1200 (Son # 2), Stock
That's why I made the extensions longer so they could be mounted above the top clamp. Below would be cleaner looking. But harder to do. Plus with the extra above the clamp gives the ability to raise the bars for touring. With just an Allen wrench.
Those spiegler bars are a lot like the Apex bars I have, same adjustability. But more expensive. You can buy individual parts for the Apex set. So if you go down you can replace just the pieces that get damaged. My buddy that crashed his speed cripple this spring just had to buy the flat bar tube. They even deliver to the track If you damage while racing.
Flynt
Hey Pat,
You probably know this already, but LSL makes a nice top triple and handlebar clamp setup for the YZF750 forks.  That's what I used on Wizard along with some FZ1 bars (slightly more narrow and I got the threaded bar ends for my Vibranators).  The fit with the fairing is perfect and I have a nice, fairly upright riding position.  The fork tubes stick up about 1/4" through the top clamp.
Hi Frank, thanks, I saw that Spiegler included a new top triple clamp in the YZF750 LSL kit.
That will be my plan B if the clip ons don't fit...
What I notice with my current handlebar setup (LSL fat bar super bike low) is that, while it is very comfortable for freeway miles, I am sitting too upright. I'm not getting my weight over the tank for proper weight distribution for cornering. I have to bend my elbows and lean way forward to kiss my mirror. It is awkward.
I think some lower, narrower bars where I will reach more forward will get my weight more centered will make the twisties more fluid.
Thanks!
I already have a Digital GPS speedo, so there is no worries about a speedo pick up on the wheel. I have plans in the future to do a complete 5 gauge Speed Hut package. That may be another year away.....the gauges are high quality and priced the same.
The company that I am getting the handle bars from is Fast From The Past
Here is the link for the 50MM ID with 70mm rise handle bars. http://www.fastfromthepast.com/56-0028
The authentic carbon fiber front fender arrived today. Photos don't do it no justice. It looks amazing.
Cool Fred can't wait to see it when you get it done.
The Tarozzi handlebars came today. These are going to work beautifully. The adjustability will be a huge benefit once the forks get installed.
Here are a few mock up photos.
