Hitch Carrier
Started by ZOA NOM, November 11, 2016, 08:58:52 PM
Just had one delivered from DiscountRamps.com. I'll post a review once installed. Here's a video for those interested in what looks like a slick answer to trailering to a Rally.
https://youtu.be/G0msWNwWD1Q
big r
That looks pretty good. An easy and safe transport option . Big R
Wow! 600 pound max is getting close but still works. And it lowers the loading height and puts the weight in a good place for a pickup. Good find Rick... A rear end hit will suck worse than a bed loaded bike. Still seems like a good option.
Quote from: FJmonkey on November 11, 2016, 09:12:20 PM
Yeah, the rear end hit is the worst fear, but it's a good tradeoff for the convenience. I really like that I can leave my shell on the truck and even set up the bed as a sleeper so I don't have to spoon with Ramos any more.   :biggrin:
I'm gonna watch closely for the weight issue. FJ data sez 585 lbs wet, so I'm hoping the carrier capacity rating is conservative. My CLass IV hitch is well above 600. Might throw some air shocks in the back with a compressor to level it.
Quote from: ZOA NOM on November 11, 2016, 10:06:30 PM
In my experience, anything that has an actual rating assigned to it. Has actually been designed to withstand 10-25% beyond the given rating.
I think the safety factor is higher than 25%. Bridges are designed with a 10X safety factor, wheelchair lifts are 4X, a bike carrier should have at least a 2X safety.
I agree, doesn't mean I won't fret every mile for awhile tho.   :bomb:
aj52
Here in RSA is somebody selling this option for motorcycle transporting.
I don't like the idea of towing a motorcycle,maybe I am just silly.
1991 FJ 1200 ABS
1991 FJ 1200
Sabre093
Great set up I've seen a 600 Ninja on one locally...I'd look into wheel straps if available to lock front tire in so front can float and no harm to fork seals...if you can get it for this application
:i_am_so_happy:
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
1984 Honda Nighthawk S 750
1982 Honda Nighthawk 450
carey
I use a lightweight version of that hitch carrier for my dirt bike.  It works well, but I suggest some sort of strap directly around the rear rim to keep the wheel from jumping out of the rail DAMHIK.
I looked into this as well, but it requires chain removal, which is too much of a PITA.
Brook
.... ZOA NOM, Transporting a heavy motorcycle on the back of a pick-up truck (hitch carrier) would scare me.
Depending on what type of truck you have.
A long/short bed or a v6/v8.
With a motorcycle that weighs close to 600lbs, that is (and I am guessing) 4 to 5 feet behind the rear axle.
I am just wondering, could that amount of weight effect the steering of your truck.
Pics...   yes, I'm concerned about load effects, but it's no different than towing a trailer with 600 lbs of tongue weight. The truck is a 2014 4x4 GMC 1500 short bed with tow pkg rated at 11900 lbs. i will feel better with air shocks to level the truck. As you can see from the rear shot, I have the front end too far to port, resulting in a slight slope. I moved the adjustable front wheel chock back to move the weight of the engine over the hitch. It sits level now, and feels very solid. I made an initial attempt to load it solo under power, and was very close to success, but backed it down when it got a little sketchy. My son helped load it for this maiden run. I think it will become easier with practice to load and unload solo.
Quote from: FJmonkey on November 12, 2016, 03:52:27 PM
How was it to load?
Sorry, I was too slow... It wasn't bad at all with two people. Just rolled it right on up and once the front wheel settles into the cradle, it'll stand up by itself. Also, I was surprised how little horizontal flex there is to the unit, since it's only contact with the truck is at the hitch. Once the bracing bracket is tightened down, the unit feels like an extension of your hitch.
