Torque question?
Started by Tor-King, October 23, 2016, 07:05:28 PM
Tor-King
How the hell do you torque a bolt when you cannot get a torque wrench on the nut?  I am attempting to tighten my bolts on the lower articulating arm connecting to the swing arm, (1986 FJ). There is just enough room for a box wrench.  You cannot possibly achieve accurate results by torquing the bolt head, can you?  Any ideas to tackle this one without purchasing additional tools?
Thanks!
1993 Yamaha FJ1200
1988 Yamaha FJ1200
1986 Yamaha FJ1200
1984 Honda Nighthawk S 750
1972 Yamaha XS-2
1972 Honda CT70
1974 Honda CT70
1992 Yamaha DT50 MX
2012 Honda CBR250R
2008 Honda CBR125R
Search for a "Crows foot socket". Then search for "offset torque wrench calculator". It can be done.
Tor-King
Quote from: FJmonkey on October 23, 2016, 07:13:28 PM
Holy crap, Mark, I was just about to ask about using one of those gadgets!!  So, using a "crow's foot socket" throws off the torque specs... that was my next question.
1993 Yamaha FJ1200
1988 Yamaha FJ1200
1986 Yamaha FJ1200
1972 Yamaha XS-2
1972 Honda CT70
1974 Honda CT70
1992 Yamaha DT50 MX
2012 Honda CBR250R
2008 Honda CBR125R
Quote from: Tor-King on October 23, 2016, 07:22:12 PM
How the Crows Foot (CF) is positioned on the torque wrench will affect the measured torque to the actual torque. If the CF is sticking o straight out then you have the wrench longer, and will generate more torque than the wrench indicates. If you stick the CF out the side then you really have not changed the length much and will get nery near what the wrench is set at. https://www.youtube.com/watch?v=tv_KHH55qdQ
FJ1100mjk
Quote from: Tor-King on October 23, 2016, 07:05:28 PM
Thanks!
Dean:
I know the fastener, that you're referring to. Just use two box end wrenches, and tighten it up good. It's a fine thread, high strength fastener M10, or M12. If you're really concerned, clean the threads really good, and put some thread locker on its threads before you thread the nut on the bolt. Cheaper than a special tool, that you won't be using that often.
Iron Balls #00002175
www.ironballs.com
4everFJ
For most nuts and bolts that aren't holding together critical parts of the engine, you don't really need a torque wrench, just common sense.
A little experience working on bikes/cars is of course also good.
1985 - Yamaha FJ1100 36Y
1978 - Yamaha SR500
1983 - Kawasaki GPZ550 (sold)
1977 - Kawasaki Z400 (sold)
balky1
Quote from: 4everFJ on October 24, 2016, 02:03:44 AM
I'd say the same.
FJ 1100, 1985, sold
FJR 1300, 2009
