93 FJ1200 Stainless Exhaust
Started by Tyars, September 26, 2016, 09:48:43 AM
Tyars
Looking for a Stainless 4 into 1 for my 93 that's in nice shape.
SW Ohio
If you want new then here is a great option http://rpmracingca.com/proddetail.asp?prod=RPMHeader. I am really happy with it, easy to install and supper light.
Tyars
Like a Vance and Hines 4-Into-1 Megaphone Exhaust System
Quote from: Tyars on September 26, 2016, 06:07:19 PM
The RPM exhaust does not need to be removed for oil changes, the V&H needs to be removed.
Tyars
Don't have a $1000 to throw into a pipe either.
FJ1100mjk
Quote from: Tyars on September 26, 2016, 07:30:07 PM
Yea, it's a tough choice at times to put out hard-earned coin for something where the money could be better used elsewhere.
Iron Balls #00002175
www.ironballs.com
ct7088
The plain steel (black painted) Supertrapp four into one doesn't have to be removed to change oil.
Chris
Tyars
Quote from: ct7088 on September 27, 2016, 06:23:15 AM
Excellent! Now does anyone have one forsale. :-)
I might be able to be sweet talked out of my Vance & Hines SS2r 4-1.
The exhaust is NOT stainless and it does NOT allow for easy access to the oil drain plug.
Tyars
Quote from: aviationfred on September 27, 2016, 12:24:23 PM
Ok Sweetie how much and what stage jet kit do you run with it?
Also what are you going to replace it with if I may ask?
I have just recently purchased this bike and I have not been inside the carbs. I will have a look this evening and give you an update and a price.
I will be getting a SuperTrapp internal disc 4-1.
I hope it's not Marty's....I have dibs on that one.
I cannot answer on the Supertrapp header, but that is not the case with the V&H.
I have on here right now that we had to remove to access the drain plug. I can get a wrench on it, but I cannot get my hand in there to turn, remove or install after draining.
That is the experience I have always had with this header.
