Clutch slave end fitting - help pls
Started by Charlie-brm, September 14, 2016, 02:20:57 PM
Charlie-brm
I am trying to order up custom stainless braided lines but the supplier and I are getting hung up on how to choose the right end fitting for the clutch slave. It's a pretty snug S bend around that cover to reach the hole, with little clearance to be wrong by more than 1/8th inch.
Does anyone have pics in their galleries of an aftermarket fitting, with close ups?
1979 XS750SF - 2005 to 2012
Order a line from RPM...... Guaranteed to fit.
1984-1987 Spiegler Stainless braided Clutch line
http://rpmracingca.com/proddetail.asp?prod=S-YA0130&cat=39
If you want Spiegler lines (they are the best IMHO) +1 for RPM. It's the easiest way to do it.
Back in the olden days before RPM became a Spiegler dealer, I ordered my lines directly from Spiegler. I paid full list price.
RPM offers these same lines for less than the Spiegler list price, so now I recommend RPM.
FYI if you want to see the various Spiegler fittings, scroll down to see all the 10mm banjo fittings. https://spieglerusa.com/standard-line
I'm going by memory, but I think I used fitting # 040 for the clutch slave.
The fittings can be rotated (clocked) so you can be sure to get any twist out of the line.
Hope this helps
Pat
Sparky84
I ended up using a spacer with the standard offset and double Banjo,
It got me out of trouble because I already had the braided line
Cheers Alan
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
Sparky84
Sorry I couldn't post jpg, kept getting 524 error, so I had to use pdf
Cheers Alan
1979 Kawasaki Z1300
Charlie-brm
Quote from: Sparky84 on September 14, 2016, 06:43:15 PM
Cheers Alan
LOL! Have you any idea how many clicks it took to download the PDF and see that pic?  :smile:
That's a nice clear image and confirms another pic I found so that's the way I'm going. Thanks.
If it's OK with you, I've posted your image inline so other readers see what you contributed.
Cheers, Charlie
Sparky84
No Worries Charlie, that is much better with the photo straight up .
Glad to help
I'll send all my photosin future for you to post  :good2:
Cheers Alan
1979 Kawasaki Z1300
Charlie-brm
Graphics and Acrobat are ma thang, y'all.
Little question: what is that spacer/collar between the fitting and the slave? I noticed that after I posted up the picture. I have an almost identical example as yours but no spacer (see image).
Sparky84
The spacer came from where I got braided lines, had to get it sent after trying to fit lines and finding this problem.
Mine would've fitted the same as yours but what it covered was Slave mounting Bolt  :negative:,
that's why I needed spacer so I could take off Slave if required without draining fluid  :i_am_so_happy:
Cheers Alan
1979 Kawasaki Z1300
