Clutch slave rep. kit : Wich one ?
Started by Vilike, September 02, 2016, 12:19:09 PM
Vilike
Hey !
I repaired the clutch slave cylinder on my 1TX about 2 years ago. It was leaking. Classic FJ issue. I used the Tourmax repair kit. After about 8000 Km run, the cylinder leaks again. So tell me guys, wich repair kit is the best of all ?
FJ1200 1TX '1986
FJ1200 3CW '1988
FZR1000 Exup 3LE '1991
Tor-King
Hi there!
This will take care of it.  Sometimes when the bore is rusted due to moisture content in the fluid, they will never seal properly again no matter how many kits you install.
https://www.rpmracingca.com/proddetail.asp?prod=Clutch%3A5EA-16381-00%3A36y-16381-00
1993 Yamaha FJ1200
1988 Yamaha FJ1200
1986 Yamaha FJ1200
1984 Honda Nighthawk S 750
1972 Yamaha XS-2
1972 Honda CT70
1974 Honda CT70
1992 Yamaha DT50 MX
2012 Honda CBR250R
2008 Honda CBR125R
Quote from: Tor-King on September 02, 2016, 01:49:44 PM
Yes, Dean is correct, although the aluminum bore gets corroded/pitted.
A quick clean up with this brake slave hone tool on a cordless drill helps clean up the bore.
However, as Dean said, sometimes the damage is too severe and you need a new slave
CutterBill
Quote from: Vilike on September 02, 2016, 12:19:09 PM
I repaired the clutch slave cylinder on my 1TX about 2 years ago. It was leaking... After about 8000 Km run, the cylinder leaks again. So tell me guys, wich repair kit is the best of all ?
How many times do you want to play this game?  Flush the brake and clutch fluid every year; replace the clutch slave every 5 years.  Consider it "Maintenance."
Bill
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
Sparky84
Quote from: CutterBill on September 02, 2016, 04:22:24 PM
Bill
+1 Bill on replace the clutch slave, I have probably replaced 5, last time was last year and I was told it might be silver but a black unit turned up :yes:
I have used a kit before with no success but I have not seen or used a brake slave hone tool, where do you get those from? I could try it on the spare units I have on the shelf!
Alan
1979 Kawasaki Z1300
1972 Honda CB750/4 K2
Tor-King
Many have used DOT 5 fluid in their clutch systems with success.  It seems to preserve the slave from any pitting as it is a synthetic and inhibits moisture.  The bonus is that if the slave does leak, it wont destroy your paint and cowling.  The only thing is the entire line and master must be flushed as it cannot be mixed with DOT 3, 4 or 5.1
1993 Yamaha FJ1200
1988 Yamaha FJ1200
1986 Yamaha FJ1200
1972 Yamaha XS-2
1972 Honda CT70
1974 Honda CT70
1992 Yamaha DT50 MX
2012 Honda CBR250R
2008 Honda CBR125R
Quote from: Sparky84 on September 03, 2016, 05:32:06 AM
Bill
Alan
I used to advise replacing the seal once only then replace the complete unit next time.
Having seen and read the "clean up" practices employed by many, and consequently the life they are getting out of them, I think the better advice is just replace the cylinder, they are not expensive.
Pat, having a cylinder hone is only half the fix. Knowing how to use it is the other half. As they go in a power drill, like any power tool, they are capable of big damage in a small amount of time. I know this because I've seen it done. A simple tool with an obvious use, but that doesn't mean you can't stuff it up, and people do. The right tool in the wrong hands can make a bigger mess than no tool at all.
Bill, I'm not sure I'd go as far as to suggest replacing it every 5 years (you're thinking like an aircraft mechanic :biggrin:), they last a lot better than that and they don't just fail and leave you stranded, they progressively start leaking. I know of one FJ still on the original cylinder and has only had one seal replaced (the current one) over 23 years/160,000kms.
Quote from: Tor-King on September 03, 2016, 09:32:22 AM
DOT 5 does not inhibit, it rejects it so the fluid and water do not mix. All the other DOT fluids absorb the water. The real advantage to DOT 5 is not damaging the paint. Regular maintenance (flush) is recommended for either type.
CutterBill
It's all about perspective...
Sometimes when we are wondering why a person has a particular opinion on a subject, it helps to know their previous life's experiences.  Now, as for me: I have 3 project FJ's, a WR400 that needs a new cam, a 4WD Jeep that I am rebuilding back to new, I'm building a welding table for my shop, I have a Bonanza in my shop that is getting a new engine, prop and instrument panel,  and I'm doing a landing gear overhaul/rig on a Cessna 310 at the local airport 12 miles away.  And I have a full-time job (engineer at a place that makes trains, if you can believe that. :dash2:)  Which is to say... I'm busy.
When Mike (streetmasters) comes over to my house, he just shakes his head.  His frequent comment is "Dude, you're nuts."  But I digress...
Anyway, as I said, I'm busy.  I really don't want to spend my time working on my toys; I want to spend my time riding/driving my toys.  So, when one of my toys develops a problem (leaking clutch slave) I just want to fix it ONCE and be done with it.  I really don't want to spend the time to take it apart, clean, hone, fiddle, reassemble, bleed... hmmm, still leaks.  Let's rebuild it again...  No.  I want to pull off the old one, bolt on a new one, and ride away.
Now, I do have a job that pays me reasonably well, and I fully understand that a lot of people don't have the luxury of so much disposable income* that they can buy a new part every time one fails.  Sure, I get that.  At times in my life when I didn't have 2 dimes to rub together, I came up with some pretty creative "fixes" to keep my wheels turning.  But if there is anyway you can afford a new slave cylinder, just buy it and be done with it.
Here's another perspective... long ago, when I was a kid blasting all over Texas on my Honda 350, the engine blew up in far west Texas.  I lived in east Texas.  If you don't know, Texas is big.  It took me 3 days to hitchhike home.  (Yeah, we did that back then.) That experience left such an impression on my young mind that I now make every one of my cars/bikes as perfect as possible.  Breaking down on the road truly sucks.  I do NOT want to be broke-down in East Muleshoe, Wyoming.  In the rain.  On a holiday weekend...
Anyway, that's my opinion.  It's all about perspective.
Bill
*and if you're wondering why I have all of this disposable income, it's not because my job pays so well.  It doesn't.  The reason I have it is because I don't have a wife, I don't have kids, I don't have a girlfriend...I don't even have a dog.  (Well... I did but he died.) I don't need a gold-digging DreamKiller in my life.  (Buy me a beer and I'll tell you the story about how, long ago, my boss was dating my gf behind my back.)   :rofl:   And I'm fairly frugal; don't need a lot of "stuff."  So there ya go.  Wow, how did we drift into that subject?  Probably too much coffee... Somebody stop me...   :flag_of_truce:
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
....or you could follow Simon's lead (Earl Svorks) and press in a Stainless Steel sleeve in the bore of the slave and have (other than seals) a life time part.
http://www.fjowners.com/index.php?topic=12294.0
ct7088
What is a good way to flush the brake system and change to DOT 5?
Chris
Quote from: ct7088 on September 03, 2016, 01:59:30 PM
I took the master & slave off, flushed both and the hoses with brake cleaner, used fresh washers and refilled. I Cycled the master with brake cleaner and took the slave apart to flush.
I swapped my '89 clutch over to DOT5 a few years ago when I rebuilt the slave and added the YZF750 m/c and braided line.  Leon can tell you what year it was... we headed out to his first FJ rally right after.
It hasn't required anything since...    :pardon:
ct7088
Chris
