Oil pump drive gear
Started by JimboOZ, August 22, 2016, 02:24:35 AM
Just pulling my 84' down and the oil pump drive gear is loose
Maintenance
2 (100%)
General
0 (0%)
Total Members Voted: 2
JimboOZ
There is no play (wear) on the splines but it moves freely back and forth on the length of the shaft.
There is just the circlip on the front and a thrust washer behind.
Normal ?
There is play on the oil pump side to compensate for expansion as the other gear is bearing mounted.
The snap ring groove is where the wear is the most prevalent.
JimboOZ
Quote from: racerrad8 on August 22, 2016, 12:30:31 PM
Thanks mate, my 84' restoration has a lot of your parts in it now
Good suppliers are hard to find
Jim
