Chains
Started by balky1, July 08, 2016, 06:40:00 AM
Quote from: a.graham52 on July 12, 2016, 07:01:05 PM
Thread jack alert...
I'm going to order my chain and sprocket set. I was going to go 18/41 or maybe 18/40. 60ish at 4k seems a bit much really. Maybe 60ish at 3750?
Also I'm converting to a gsxr rear wheel as well. What a good tinsel strength? 530?
18/41 (with 17" wheel) is 3750@60mph.
I'll spare you the tinsel jokes. There is plenty of info here on chains as discussion about it comes up regularly. Any good brand name 530 chain will have a tensile rating that will handle the FJ power and weight. 530 is the size.
Do not go cheap on chain! You can get away with skimping on a lot of things but never chain.
fjbiker84
I put the RK chain on my 84 along with the Supersprox sprockets.  Love the look and wanted the best chain, too. Wasn't aware of cheaper chains breaking - knew they would wear out more quickly and develop tight links - but yikes!  After seeing some of the photos of what can happen, I'm glad I listened to the guy at the bike shop that recommended it.
a.graham52
Lol. Tensile is not In my phones vocabulary lol. I wastill given an estimate of 250 bucks for a whole set. Is 120 link chain going to be long enugh with a 18/40?
Tuneforkfreak
I think 110 links is stock length? My bike was geared stock 17/40 and 110 links ( if I'm correct on stock length) fit it fine with plenty of adjustment. When I changed my gearing to 18/38 the 110 link chain worked fine with an adequate amount of adjustment still. I'd say 120 links will be plenty, you'll just more than likely have to cut it to size.
Yamahas from my past,
IT465, IT200, YZ80. 350Warrior, Kodiak400, Kodiak450,
Various others include
XR600, KX500, KDX200, ATC250R, ATC350X, ATC 200S
Currently ride
FJ 1200 , DRZ400, Yamaha Viking, Suzuki Samurai dirt mobile
Quote from: a.graham52 on July 13, 2016, 12:01:31 PM
Yes.
It will be too long.
Get the 110-link chain. It's plenty long enough.
18/38 with 110 links works perfectly. I find that gearing is great for the open road, still no shortage of quick overtaking pickup, still good around town. I actually went semi cheap on my last chain from the UK, a SSS 530 model. So far has been excellent, (3 years old), but for my next one will probably go RK or similar.
Love your wheels Alan
balky1
My DID endless chain, ZVXM, and JT sprockets cost cca. 150€ from Germany.
FJ 1100, 1985, sold
FJR 1300, 2009
I believe the only time you would need a 120 link chain is if you install a longer swingarm.
My FZ1 swingarm is around 2" longer and 112 links is what is required so I have to purchase 120links and cut 8 off.
Quote from: fjbiker84 on July 12, 2016, 11:01:53 PM
I have been looking at the Supersprox hybrid aluminum/steel sprockets. Can you please tell us your impressions with weight savings and longevity of wear.
I just purchased a 530 DIDzvmxg 114+ master for $154 shipped off Amazon. Got here in 2days.
For the 89. Having a hard time finding a rear sprocket for the 93gsxr600 wheel. With 40t.
The 600 uses a 5 bolt 110mm bolt pattern. Have a JT on there but it doesn't have a number on it. And I can't remember what bike it was for. The gsxr600 only goes down to 42t.
I have a supersprox stealth 38t for the r1 wheel. For when I put the r1 braced swinger (about 2 1/2" longer) on the turbo bike.  Looks good quality. But haven't gotten to use one yet.
Their website says it has been used on 600hp Street bikes/ correction, it says street monsters.
Quote from: giantkiller on July 14, 2016, 12:35:35 PM
Here is the list of other bikes that use the same SPROCKET CARRIER as the '93 GSXR600. Maybe this will help in finding a 40t sprocket.
http://www.partzilla.com/parts/detail/suzuki/SP-64611-17C01.html
