Does it have a rev limiter?
Started by YamaHammerYT, July 07, 2016, 03:56:39 PM
YamaHammerYT
This question has been bothering me for a while and I've yet to get a conclusive answer...
Does the non-California spec 1987 FJ1200 have a rev limiter? I've heard yes, no, only the new ones, none at all...
Thanks in advance!  :good2:
Yes!
now go ride it , pin it in 1st gear till you find it.
nuetral dosen't count.
moparman70
Don't listen to Mark --- but if you ask me it doesn't as I have gone into the upper limits without any retardation ( apart from the rider at the time(
sc2
YamaHammerYT
Quote from: Mark Olson on July 07, 2016, 05:31:59 PM
Yes!
Yeah, I think I'm good... Having some shifting issues from first to second that need investigation. Long story short, it likes to find neutral from time to time instead of second. False neutral tends to pop up as well, resulting in a brief over-rev as I try to get back into it.
krusty
Quote from: YamaHammerYT on July 07, 2016, 10:59:29 PM
Yes!
Have you checked the placement of your shifter? Set it so that it gets a full "throw" when you shift up, you may have it set too high.
84 FJ1100 x 2
85 FJ1100
89 GL1500
60 Colleda 250TA x 3
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
4everFJ
The Detent shift kit from RPM is THE solution for that. Highly recommended and easy to install.
1985 - Yamaha FJ1100 36Y
1978 - Yamaha SR500
1983 - Kawasaki GPZ550 (sold)
1977 - Kawasaki Z400 (sold)
PaulG
Have you bled your clutch lately?  I was having a similar issue a few yrs ago.  Once the clutch was bled it disappeared.  Also, if you have original rubber lines they may expand too much under pressure.  Plus a sticky slave cylinder maybe.  These may not allow the push rod to fully engage.
I was getting the bike serviced at a shop before a long trip, and this is what I was told re the bleeding aspect.
1992 FJ1200 ABS
YouTube Channel Paul G
Bent shift forks on my '86 result in a rev-limiter like event around 7K RPM. The gear pops in and out as if the power is being cut and restored. A well known and documented problem on the early FJs. The RPM shift kit will not fix this, but it will result in smother shifts. I have the shift kit and recommend it. The 2nd gear issue requires one of two approaches. Shift short, not fun but avoids making the problem worse as the shift fork will only bend more with the added stress. Split the cases and get the gears under cut and shift forks upgraded. Then you can get your 2nd gear Kookalooo back.
YamaHammerYT
I've actually been considering the shifter and the detent kit. I still need to do some diagnosing and other work here and there. Also, the clutch had been acting a bit strange when I replaced all the seals (The hydraulics were completely shot when I got the bike). It seemed to take forever to bleed, and even longer to build up pressure. Haven't had any pressure issues since as far as I can tell, but it doesn't hurt to bleed it anyway. I'm disinclined to blame the clutch, as it idles normally going down the road if I pull the clutch in, as well as at a stop. Doesn't seem to drag at all. It's most likely a bend shift fork from what I've read. Thanks for the input!
Also of note regarding the shifting issues: Sometimes when it sticks in neutral, it REALLY doesn't want to go out, and will actually grind the gears, even with the clutch in. This is rare, but it has happened once or twice. Wondering if it might be a combination of issues, actually... Time to check hydraulics. Again.  :morning2:
Quote from: moparman70 on July 07, 2016, 10:12:12 PM
sc2
Exactly what RPM did you reach during your retard moment? I would like to know .  :mail1: :mail1:
Yes!
neutral doesn't count.
Ok , here is the info.  Your shift fork is bent.
The early FJ's from 84-87 and some 88's, have weak forks and bend with aggressive riding. This will result in a bent fork and second gear not holding under acceleration usually in the higher rpm's.
Once the fork is bent you must split the cases to replace it ... sorry.
The 89-93 FJ's have stronger shift forks.
with my 86 I started jumping out of 2nd gear under load about 10k rpm , never missed a shift but the pressure of the trans at that rpm did its evil work and soon it would jump out at 9k then 8k and within a couple of years 6k . I would have to wind up 1st gear then let the revs drop to 3k before engaging 2nd gear or it would hit false neutral and grind.
So even with taking it easy the problem got worse.
The solution was to split the case and replace the shift forks and have the trans gears undercut.
I wanted my trans working again  so I opted for the full Monte and replaced all the gears , all the forks with beefy xj1250 ones , shift detent kit and whatever else was needed while it was apart.
It is now bulletproof and shifts like never before ,,, just awesome ...Many thanks to RPM Randy  :good2:
My 86 FJ is the same as your 87 except for the paint scheme and my rev limiter kicks in at 12.5K .
There will be nay Sayers about the rev limiter and this is due to the year of FJ you have ... the early FJ's rev higher and the later ones can limit earlier around 9.5k-11k depending .
If you don't believe me ask RPM Randy and CO.
My condolences to those of you who yet to find your rev limit . perhaps one day your balls will finish dropping.  :rofl2:
Quote from: Mark Olson on July 09, 2016, 01:52:03 PM
..... my rev limiter kicks in at 12.5K .
Mark, I'm not having a shot at you personally but suggesting people hold the throttle wide open until something happens seems like reckless advice.
It has always been a bit of hobby horse of mine and quotes like this are like finger nails down a blackboard....
An FJ engine doing 12,500 rpm has a piston speed greater than an F1 engine at 18,000 rpm and each piston weighs (literally) a ton more. It is a great testament to the FJ engine's robustness that it doesn't fly apart at those revs.
There are many reasons not to over rev an engine, we all know about the inertia of the piston just after TDC on the exhaust stroke and the load on the oil, rod, bearings, piston, gudgeon etc having to reverse the pistons direction at enormous speed. The load on those components at that point is literally measured in tons.
What is not as commonly known is the limitations that piston speed places on engine lubrication, specifically ring and cylinder lubrication. Exceeding this piston speed can cause damage to the engine which may not (but can) result in immediate failure but will shorten it's life.
It's ironic that the very people who push engines to their limit, race engine builders, have the greatest understanding of this.
If you are interested in the subject, do your own research, my views appear to be on the nose, as are 3rd party references  :biggrin:
I'm not wishing to buy into the discussion on the existence of rev limiters on FJ's but no manufacturer is going to fit a rev limiter that allows and engine to be revved a staggering 30% beyond it's design limitations and into a realm of engine speed that even race engine builders steer clear of, the limiter normally cuts in just after redline, for obvious reasons.
Rev limiters are electronic and usually consistent. You say it changes from bike to bike "depending" ... depending on what?
Finally, it begs the question, why would you want to rev and engine so far beyond it's design limits, it stopped making power 3000 rpm ago?
It was when my balls dropped I realised the folly and the risk of over revving an engine just for the hell of it :lol:
Mark, is it possible that being so far over redline the engine has just hit the wall and can't rev any further? I've never experienced a rev limiter so far above redline and the piston speed suggests there is no way it was by design.
I thought this was discussed not long ago without a definitive answer.
I have done my research on actual Running FJ motorcycles .... Of course I understand the inherent danger of overrevving any engine into the red zone. I worked as an engine machinist and builder for years along with racing the engines I had built.
when this rev limiter question started years ago even before this forum existed I found the answer for myself .... perhaps my tach is optomistic.
I do not pin it to the limiter every time I ride, that WOULD be reckless.
However you choose to ride your fj is up to you. If you never miss a shift or experience high rpm clutch slippage you are lucky.
My suggestion to the op was valid from my perspective . It was the simplest way to determine where his limiter kicked in.
So Noel , Since you claim your balls have dropped would you please post what rpm your fj's rev limiter kicks in.
Don't worry , your year FJ should be in the 9-10k range.
Oh yeah, the reason there is a difference is that there are 2 different factory ign systems for the fj.
Most of the Drag racing fj guys have switched to the dyna ign so they can lower the rev limit for launching as they bounce it off the limiter waiting on the green light.
For the rest of you reading this post , simply do what you always do when riding your fj. Wind it up till it stops making power and shift. Have Fun :good2:
Quote from: Mark Olson on July 10, 2016, 01:41:50 PM
The problem is my RPM 1380cc engine doesn't seem to stop making power.....it scares me. Makes me cry. Makes me whimper. 90 mph wheelies do that.
My balls, once dropped, have now receded....it is NOT funny......but sure is fun.
MOMMY!
Quite right Mark and the more information the better informed the choice.
I don't know. If flogging it, I change at 9k, if not watching closely maybe 9.5k. It's never been any higher.
