September 24, 2023, 08:45:34 PM *
News:            Enjoy your FJ
   Home   Help Login Register
Pages: [1] 2 3 4   Go Down
  Print
Author Topic: 1993 ABS reccommissioning  (Read 26130 times)
JPaganel
Hero Member
Offline Offline
Gender: Male
« on: June 30, 2016, 02:51:41 AM »
So, I took the first brief look into the innurds of the new to me 1993.
This looks to be a former enthusiast's bike that has fallen on hard times. Corbin seat and bags point to that, as well as the relay mod. I'm not sure yet if it's for headlight, coils, or both, but there is a pair of relays under the front fairing wired to the battery.
First things:
Top of engine is way crusty. Oil leak must have been around a good long time.
Battery is completely dead.
The PO story of carb cleaning and rebuild by a mechanic friend is questionable. Throttle does not move, looks like carbs are stuck, and the choke is sticky.
Clutch flops with no pressure whatsoever. I am going to look at a new MC and hose, and I have a slave cylinder seal kit ready.
Logged
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Steve_in_Florida
Super Hero Member
Offline Offline
Gender: Male
Terrapin the 1200cc ThunderKitty
WWW
« Reply #1 on: June 30, 2016, 06:40:06 AM »
Your new acquisition looks like a good platform to start from.
I look forward to your posts, as I'm refurbishing a couple myself.
Logged
`90 FJ-1200
`92 FJ-1200
IBA # 54823
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #2 on: June 30, 2016, 02:18:27 PM »
Well, no question as to why the clutch circuit is bone dry...
Logged
1993 FJ1200 ABS
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #3 on: June 30, 2016, 04:50:28 PM »
New hoses next to the original 1992 vintage hoses.
Figured, if I'm doing this, might as well do it right.
Logged
1993 FJ1200 ABS
Global Moderator
Gold Contributor
Super Hero Member
Offline Offline
Gender: Male
« Reply #4 on: June 30, 2016, 05:25:08 PM »
Atta boy good
Logged
wirehairs
Jr. Member
Offline Offline
« Reply #5 on: July 01, 2016, 08:49:53 AM »
You were smart to get blue lines.  I've figured out that the plastic in the clear ones will always yellow in time (like the ones I bought!   ireful ); colored ones will look better over time.
Logged
Tuneforkfreak
Sr. Member
Offline Offline
Gender: Male
« Reply #6 on: July 04, 2016, 10:30:08 AM »
I think it would be cool to have a project like this progress in video form on you tube. I'd watch that like a TV show. Looking forward to seeing your progress, was the fairing missing or rotted off from the slave leaking on it for so long? That looks like its been shitty for a good while.
Logged
Yamahas from my past,
 IT465, IT200, YZ80. 350Warrior, Kodiak400, Kodiak450,
Various others include
XR600, KX500, KDX200, ATC250R, ATC350X, ATC 200S
Currently ride
FJ 1200 , DRZ400, Yamaha Viking, Suzuki Samurai dirt mobile
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #7 on: July 04, 2016, 01:43:14 PM »
Fairing was not on the bike. I think it's in one of the bags. I haven't really looked at it.
Logged
1993 FJ1200 ABS
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #8 on: July 04, 2016, 10:23:44 PM »
Today was washing day.
There was some serious crusticity here.
So, after some soap and brush it turned out the engine isn't actually black...
Although, by the feel here I probably should replace the clutch rod seal
Logged
1993 FJ1200 ABS
TexasDave
Super Hero Member
Offline Offline
Gender: Male
« Reply #9 on: July 04, 2016, 11:31:22 PM »
Looks like you need some valve cover bolt gaskets also. Nice work so far.  Dave
Logged
Tuneforkfreak
Sr. Member
Offline Offline
Gender: Male
« Reply #10 on: July 05, 2016, 07:59:31 AM »
Eww that clutch rod seal looks a little outdated.
Logged
Currently ride
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #11 on: July 05, 2016, 08:35:23 AM »
Already have the bolt seals. Gasket is en route.
Yeah, feels a little loose, too.
Logged
1993 FJ1200 ABS
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #12 on: July 05, 2016, 11:20:17 PM »
The slave cylinder is not inspiring confidence.
The bore is porous. I don't know that I can buff it out to where it won't leak.
Mulling over getting a new one from Randy.
Logged
1993 FJ1200 ABS
Super Hero Member
Offline Offline
Gender: Male
Melbourne (Aus.)
« Reply #13 on: July 06, 2016, 01:47:03 AM »
Get a new one, you'll be chasing your tail trying to make something of that.
Safety notice to no one in particular. Experienced tradesmen, even knowing every shortcut, tip and trick, will never use anything on a hydraulic cylinder other than a proper tool. Knowing how to use it helps too. The most they might do by hand is "wipe" it with a bit of emery, but that's it.
Some of the "cleanup" and "servicing" methods described here from time to time would make them cringe, especially on brake components.
It is also good practice to never re install cups once removed (such as for "servicing"). Over time they become mated to the bore which is something you can't match when re installing them. Probably won't fail but certainly won't last as long.
Logged
"Tell a wise man something he doesn't know and he'll thank you, tell a fool something he doesn't know and he'll abuse you”
Super Hero Member
Offline Offline
Gender: Male
Melbourne (Aus.)
« Reply #14 on: July 06, 2016, 03:09:49 AM »
.....IMO
Logged
Pages: [1] 2 3 4   Go Up
  Print
Jump to:
SMFAds for Free Forums
Valid XHTML 1.0! Valid CSS!
