FJowners.com
December 03, 2023, 06:31:59 PM *
Welcome, Guest. Please login or register.
Did you miss your activation email?
Login with username, password and session length
News:            Enjoy your FJ
   Home   Help Login Register
Pages: 1 [2] 3 4   Go Down
  Print
Author Topic: 1993 ABS reccommissioning  (Read 26564 times)
Tuneforkfreak
Sr. Member
Offline Offline
Gender: Male
« Reply #15 on: July 06, 2016, 11:58:42 AM »
Well that explains the cruddy nasty look of the outside before you tore it down, that's pretty bad shape. Ive never dove into this subject but can that material be honed? I'm assuming its either magnesium or aluminum? Looks like you can see a tiny bit of the old finished surface. Not that I would do it if the new part was available, just asking the question in general.
Logged
Yamahas from my past,
 IT465, IT200, YZ80. 350Warrior, Kodiak400, Kodiak450,
Various others include
XR600, KX500, KDX200, ATC250R, ATC350X, ATC 200S
Currently ride
FJ 1200 , DRZ400, Yamaha Viking, Suzuki Samurai dirt mobile
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #16 on: July 06, 2016, 12:23:18 PM »
It's aluminum.
I've been advised things ranging from emery cloth to Scotchbrite, to hones.
I have a brake service shop not too far from me, maybe I will check with them.
Logged
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Super Hero Member
Offline Offline
Gender: Male
Forum Member #16
« Reply #17 on: July 06, 2016, 12:27:04 PM »
how does the piston look ?
If it was me , I would get a new one ...
Logged
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #18 on: July 06, 2016, 01:26:23 PM »
Piston was a bit rusty, but I cleaned that off.
Logged
1993 FJ1200 ABS
Tuneforkfreak
Sr. Member
Offline Offline
Gender: Male
« Reply #19 on: July 06, 2016, 02:24:14 PM »
Heck it might be worth a shot if the rebuild kit is not that much? If it was me I'd probably try to clean it up first and at least see what the outcome was before deciding on replacement part or rebuild.
Logged
Currently ride
Global Moderator
Gold Contributor
Super Hero Member
Online Online
Gender: Male
bono malum superate
« Reply #20 on: July 06, 2016, 02:29:18 PM »
I rebuilt my slave on my '86, used Scotchbright (not sure what grit). When I got my '89 the salve was shot so I tried to rebuild it. It was past its prime, I used the rebuilt one off my '86. It is still going strong. So they can be rebuilt and some are due for the scrap bin. The cost of a new one is not that bad either.
Logged
ct7088
Full Member
Offline Offline
Gender: Male
« Reply #21 on: July 06, 2016, 09:44:12 PM »
I would expect to find a semi circle of deeper corrosion at the bottom of the bore behind the seal. If you do find that corrosion toss it in the trash.
Chris
Logged
Chris
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #22 on: July 07, 2016, 10:58:20 PM »
Moving right along.
Pulled the carbs today. The reason throttle wouldn't turn was the previous owner managed to get cables on backwards. Carbs look clean, and have 42.5 pilot and 110 main. Pilots seem a bit rich for stock intake and exhaust, but who knows, it may run well.
Speaking of previous owner, he found more stuff which I picked up today. A full set of brake rotors, a chin scoop, a second set of keys, and an owners manual.
Wondering if I should change the shift shaft seal. It's greasy as hell down there, so I don't know if it leaks or not. Output shaft seal seems to be OK, no crust behind sprocket.
Also found a burr on one of the throttle cables. Probably should replace those, too.
Logged
1993 FJ1200 ABS
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #23 on: July 08, 2016, 08:16:58 AM »
Another interesting find from last night - the neutral switch is missing a screw. Probably should replace that, too...
Logged
1993 FJ1200 ABS
Tuneforkfreak
Sr. Member
Offline Offline
Gender: Male
« Reply #24 on: July 08, 2016, 09:36:56 AM »
Oh man I would love to read through that owners manual. Score on the extra parts. good2
Logged
Currently ride
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #25 on: July 08, 2016, 12:39:11 PM »
After a quick consultation with Randy, I put in an order for 40 pilots and 112.5 mains. Also, a new slave cylinder and some miscellaneous bits.
Logged
1993 FJ1200 ABS
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #26 on: July 09, 2016, 01:46:12 PM »
Got into the carbs last night.
They seem to be actually clean, which is nice. Going to get new jets in and see how it goes.
Logged
1993 FJ1200 ABS
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #27 on: July 09, 2016, 05:41:10 PM »
Doing some more degreasing today in the sprocket area.
Also, electrical work.
Since I am replacing clutch master with an FJR one, I am also changing the clutch switch plug. The FJ plug has two wires, the FJR has three.
Here is the new plug installed next to the old one:
The plug is Corsa Technic part MTW-3S
I didn't have to replace the terminals - they are the same. I just popped them out of one plug using a piece of steel wire and popped them into the other. The correct positions are the two outer ones, and the middle should be empty.
This is the correct plug for the emissions connector on the right side of bike, not used in non-California models. Corsa Technic part 250ARM-2P
This plug will be used to run a relay for a power feed to the front of the bike, where I will reconnect the headlight relays and the future heated grips, when I get them.
Logged
1993 FJ1200 ABS
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #28 on: July 12, 2016, 10:17:46 AM »
RPM package showed up last night, but I didn't have it in me to do any work.
Going to see about picking up a screw for the neutral switch today, too.
Logged
1993 FJ1200 ABS
JPaganel
Hero Member
Offline Offline
Gender: Male
« Reply #29 on: July 15, 2016, 09:06:42 PM »
Bought a HF soda blaster and tried it out on the sprocket cover. Then, hit it with rattlecan engine paint.
I think the result is pretty decent.
Logged
1993 FJ1200 ABS
Pages: 1 [2] 3 4   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.10 :: SMF © 2006-2009, Simple Machines LLC
SMFAds for Free Forums
Valid XHTML 1.0! Valid CSS!
