Score.
Started by JPaganel, June 27, 2016, 08:38:59 PM
JPaganel
So, this happened.
1993 ABS. Corbin seat, full Givi bags. Cruise control. Supposedly clean carbs.
Classic oil leak from top front - bet it's the valve cover gasket and donuts.
Clutch seems to have no pressure whatsoever.
Side panels are floptastic.
Battery is toast, so unclear how good of a runner it is.
Still, not bad for $700.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Tuneforkfreak
That actually made me sick when I read $700, man you guys grab up some deals now :good2:
Yamahas from my past,
IT465, IT200, YZ80. 350Warrior, Kodiak400, Kodiak450,
Various others include
XR600, KX500, KDX200, ATC250R, ATC350X, ATC 200S
Currently ride
FJ 1200 , DRZ400, Yamaha Viking, Suzuki Samurai dirt mobile
FJ1100mjk
Good job! Glad that you got it. I saw that pop on CL, and knew it wouldn't last out there very long.
Iron Balls #00002175
www.ironballs.com
$700 ????
What happened? Did you bring a gun?
JPaganel
Quote from: Pat Conlon on June 27, 2016, 09:31:41 PM
$700 ????
I did, but I didn't have to use it. I just killed a nearby squirrel with my my mind.  :crazy:
1993 FJ1200 ABS
yamaha fj rider
Congrats, nice find.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
PaulG
Heres a deal you can't miss.  I will drive the 1,000 miles from Toronto to Minnesota and pay you $800 for it!  That's even US dollars!   :good:
You didn't even feel guilty?  Well I wouldn't either really....   :pardon:  Congrats!  Now wheres the cigars?   :drinks:
1992 FJ1200 ABS
YouTube Channel Paul G
jscgdunn
90 FJ 1200 (Son # 2), Stock
wirehairs
Very nice!  I have the same bike, with the Corbin seat that I just got done with all the maintenance.  Man, those 9 brake/clutch lines were a pain..  I'm local so happy to chat to you about it.
Now just sell me that luggage rack!!  :biggrin:  I have the tail case, but need the side ones.
JPaganel
Quote from: wirehairs on June 29, 2016, 09:23:54 AM
I might actually still have your phone number. :)
HA!
You oughta see the set of bags I got for the XJ... Minty.
Also, I got with a friend in Germany and there is a set of dual-caliper Euro-spec XJ550 forks headed my way. ;)
1993 FJ1200 ABS
wirehairs
How is that XJ550 working now?  I just have to swap out my front springs and oil for progressives on my Seca and apply the new decals and I'm done.
I just replaced on the o-rings in my FJ1200 and all brakelines, and darn it, the front calipers are dragging just a bit on the disks.  No idea why.  I did change all the seals.  Unless someone from this group has a better idea, I'm going to unbolt them and see if I can use some kind of clamp to push them in a bit (without detaching the lines) to see what happens.  I can't believe that a seal was put in wrong or there's remaining corrosion on the pistons, because I looked at them closely.  Come visit if you want to see it.  I'm at hwy 36 and Rice St.
JPaganel
Quote from: wirehairs on June 30, 2016, 10:20:34 AM
It's running pretty good, except the front brakes. They are kinda weak.
I'm hoping the conversion to dual disk will fix that.
Dragging might come from air in the lines or from problems in the master. Never really seen it be a caliper problem.
1993 FJ1200 ABS
TexasDave
The heck with the xj! How is the new FJ coming along? Nice find.   Dave
JPaganel
I started a project thread.
1993 FJ1200 ABS
