Leaking through overflow
Started by chiz, June 14, 2016, 08:22:52 PM
chiz
Howdy folks
  My left carb is leaking when a remote gas tank is hooked to the carbs. I can't seem to fix it I just put a new o ring on the seat no diff ,,,, is this an assembly error or do I need new bits, and what would they be? Thanks
Lez
Binding on float pin
Float rubbing/hitting on edge of fuel bowl.
Float leaking
Needle binding or not in good alignment to the seat
Hope some of this helps.
oldktmdude
Quote from: movenon on June 14, 2016, 09:27:43 PM
Float leaking
Float level too high.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Bearly Flying
So it only leaks with the remote gas tank?
That would indicate an install problem with the remote tank, too much static head? And that carb is the weakest link????
Don
85 FJ1100  1250 big bore kit, ported, cammed.... Hooligan Bike
05 FJR 1300  Aux Fuel Tank, Russel Seat  Long Distance Bike
And a whole whack of RC Aircraft
Is the bike on the centerstand or kickstand ? ....... put it on the centerstand.
Picopower
My 85 had gas leaking out of vent tube. I had the carbs off a couple of times before and was concerned
about the needle and seats condition In each carb. I bought four Yamaha, not after market needle and seats
From randy and Robert at RPM. I kept the carbs together. Didn't separate. And payed close attention to
the float positions, cause I didn't want to mess with adjusting float levels. Don't have a measurement tool
and know I would screw it up.
So I bench measured the needle seat height, and it was identical to the Yamaha float and seats that Robert sent me. So I figured that the new ones would would work w/o bending float tangs. What a pain to get the
tank on and off, with the tight fuel line placement. Not to mention, getting the carbs on and off, making sure
they don't suck Unfiltered air. Anyway, the bike does not leak and runs perfect. RESULT!
Must be clean living. My old needle and seats didn't look that bad. But rust can hold them open, and the needles can hang up on sides and not drop down to hold fuel back. It's about $80 bucks for four I think and
I had them in two days. Good luck, take your time, and try not to cuss.
1975 GL1000
1976 GL1000
1976 BMW2002
chiz
Thanks for replys... going to order some bits.
