Routing for carb drainage tubes
Started by wirehairs, June 14, 2016, 08:27:45 AM
wirehairs
Silly me forgets where to route my carb's drainage tubes now that I've rebuilt them.  Was there a hole for them where I've rebuilt a missing section of my rubber divider, or do they go in the gap near the anti lock brake unit?
On both my '86 and '89 they are routed between the swing arm pivot and the transmission case. This way any fuel is drained to the ground and not on the bike.
jscgdunn
There is a wire clip on the right side of the transmission case to route the hoses to.
90 FJ 1200 (Son # 2), Stock
Picopower
After I had my carbs off, I just routed three out one side and three out the other. Then after I got the carbs
hooked up I went back and tucked the big ones down out of site,and let the little ones hang out the sides.
1975 GL1000
1976 GL1000
1976 BMW2002
