fairing removal
Started by big r, May 13, 2016, 11:34:12 AM
big r
I know it is here somewhere here but I can,t find it. I have a 1986. Thanks guys. Big R
You have two options for fairing removal. Removal of just the plastic or the plastic with the sub-frame. The lower black fairing protectors hide a fastener for the side scoops. The rest is look and remove as you go. To remove just the plastic you will need to use a socket extension and remove the bolts on either side of the headlamp. A bit of a pain but that is how i do it. Make sure you have the bolts in hand before pulling the fairing off. Or you may end up learning to plastic weld like me to fix the damage. The other option is remove the 4 bolts holding the sub-frame. This was my choice before I added HID and all the bits for it that got connected to the sub-frame. Either way you will need to remove the windscreen to get to some of the fasteners.
4everFJ
Quote from: FJmonkey on May 13, 2016, 11:46:13 AM
Wow.., they really made it difficult for the 1200..
On the 1100, it is 6 easy access bolts and it just lifts of (not that it helps the OP much..., sorry).
1985 - Yamaha FJ1100 36Y
1978 - Yamaha SR500
1983 - Kawasaki GPZ550 (sold)
1977 - Kawasaki Z400 (sold)
big r
Thanks Mark. I knew there was a fairly easy way to do it.. Big R
