Carb vacuum ports
Started by selecw, March 28, 2016, 12:34:58 PM
selecw
Guys
I am in the process of removing the CA emissions crap from my FJ. Specifically I removed the two canisters that sit behind the oil cooler (which I just replaced with one of Randy's).
Which ARE the vacuum ports? I've looked over the carb maintenance thread but can't work its out.
I know I need to cap the vacuum port on the #2 & 4 carbs to prevent a major vacuum leak.
Thanks!!
selecw
OK, after speaking to RPM I worked it out. It's the ports that have two heat shielded tubes coming out of them.
