what's this
Started by theLeopard, March 21, 2016, 09:35:42 PM
theLeopard
1992 FJ1200
This is for machine work, it indexes the valves...
theLeopard
oh, i probably wont need that then, i don't have machining equipment in my garage.
thanks monkey  :hi:
1992 FJ1200
Steve_in_Florida
Leopard,
Those are "Valve Keepers". A pair of them will fit around the end of each valve stem and "keep" it from falling into the combustion chamber.
You'll find them underneath the valve shims when you do a valve adjustment.
Unless you're prepared to remove your head for a full-on valve job, then you probably won't need any of these.
Quote from: theLeopard on March 21, 2016, 09:35:42 PM
https://www.rpmracingca.com/proddetail.asp?prod=Head%3AValveKeeper&cat=31
`90 FJ-1200
`92 FJ-1200
IBA # 54823
rlucas
Quote from: Steve_in_Florida on March 22, 2016, 09:15:08 AM
Leopard,
Kill-joy.   :blum2:
theLeopard
wait, so are those a tool or a functional engine part?
i'm trying to budget an overhaul of sorts, lots of rubber bits & gaskets to replace.
1992 FJ1200
CutterBill
Well, this should be interesting.   (popcorn)
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
Valve Keepers are reusable but you will need a valve spring compressor tool.
If Randy doesn't offer one, try Pit Posse.
theLeopard
1992 FJ1200
theLeopard
1992 FJ1200
Quote from: theLeopard on March 23, 2016, 02:59:58 PM
:dash1:
sold out:
No, there is one in stock, but you added it to your first shopping cart, along with the air filter and that took them out of stock. I deleted your first shopping cart and they are back in the inventory.
http://rpmracingca.com/proddetail.asp?prod=Carb%3Asyncpro
theLeopard
dangit, i blew my budget this week on seals and gaskets  :dash2:
kinda figured that's what happened. thanks for keeping on top of things randy, will buy some more parts ~~wednesday.
1992 FJ1200
