The damnable headlight adjuster - great solution.
Started by JPaganel, March 18, 2016, 10:44:18 PM
JPaganel
I am now in possession of a great little thing that is going to forever resolve the silly broken adjuster.
The thing in question is this:
http://www.mcmaster.com/#drive-sockets/=11lmv5r
1/4" Square Drive Socket, 4-Point Standard, 3/16" Size, 7/8" Overall Length
McMaster-Carr part number 5543A11
This socket fits snugly over the square adjuster screw and can be turned with any 1/4" ratchet with a U-joint. No drilling needed, although I suppose if you wanted to mount it permanently you could drill a hole for the pin.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
FJ1100mjk
Quote from: JPaganel on March 18, 2016, 10:44:18 PM
It appears that others have...
http://www.fjowners.com/index.php?topic=7513.0GT
Iron Balls #00002175
www.ironballs.com
JPaganel
Quote from: FJ1100mjk on March 19, 2016, 07:29:44 AM
Not quite the same thing.
1/4" u-joint in reverse fits over the bolt loosely. I'm not sure that it would work at all without the pin. Also, there is the matter of drilling the other end for the handle.
Mainly, buying this socket would let you not do any drilling at all. If you don't have a drill press, drilling a socket would be a major pain.
1993 FJ1200 ABS
Thank you JP, just the fix I was looking for...my McMaster-Carr order is placed..
Cheers and thanks again!   Pat
