Mi Brakes
Started by homerfj1100, March 09, 2016, 04:58:47 PM
homerfj1100
I finally got down to fixing the crap front brakes on my 84/85 FJ11 and the solution gave me a surprise. 2 finger stopping. I've had some blue spots for a few years and could not be bothered with the expense of a front end swap for FJ12 forks. Hassle and you end up throwing away a set of good forks.
So I found some adapters for a VMax. Still, I bought them but was a wuss. Bought a few yards of braided hose. Guessed the banjo fitments. Really. Guessed. And they fitted. With a few problems that I eventually fixed. Not sure how I post pics but will if you wish. Ta. Tony
Homerfj1100
Looking polished and cleaned, 2 finger braking means it performs as well as it looks.
Looks great.... :good2:
krusty
Did you check that the disc contacts all of the pad faces? I did a FJ12 front swap using the 4 pot FJ calipers but retaining the 16" wheel and found that I needed Vmax discs which are about 10mm bigger in diam.
84 FJ1100 x 2
85 FJ1100
89 GL1500
76 CB750F1
72 CB350F
63 C92 x 2
59 C76
62 C100
63 C100
60 Colleda 250TA x 3
63 Suzuki MD50
77 DT125E
77 DT175E x 2
79 DT250F
It does look like it's only using the outside half of the disc. Looking at the rub marks on the disc.
the fan
I'd like to see a straight on photo. From this angle it does not look like the caliper is properly aligned with the rotor and the pads are not getting full engagement. I may simply be an optical illusion, but it sure looks off in this pic.
Quote from: the fan on March 10, 2016, 11:35:00 AM
[edit] After looking at other pics online, one had the note: "You will also need to fit the 298mm flosting discs as fitted '93-'07, (as the original '85-'92 discs are too small)."
How big are the early FJ rotors?    :pardon:
Good catch. Early FJ vented rotors were 282mm OD
4everFJ
Nice, but the brake lines for the anti-dive should be routed on the inside of the fork legs  :good:
1985 - Yamaha FJ1100 36Y
1978 - Yamaha SR500
1983 - Kawasaki GPZ550 (sold)
1977 - Kawasaki Z400 (sold)
krusty
Quote from: krusty on March 09, 2016, 10:37:44 PM
These are the ones I fitted. They're working great.
http://www.ebay.com.au/itm/2x-Front-Brake-Discs-Rotor-Fits-Yamaha-VMX-12-V-Max-1993-2007-VMX-1200-VMax-XVZ-/291397891981?hash=item43d8aaf78d:g:jVYAAOSwPhdU9r78
84 FJ1100 x 2
85 FJ1100
89 GL1500
76 CB750F1
72 CB350F
63 C92 x 2
59 C76
62 C100
63 C100
63 Suzuki MD50
77 DT125E
77 DT175E x 2
79 DT250F
CutterBill
If someone will bring me their early FJ, or at least the entire fork/wheel assembly, and some blue dot calipers, I can machine some proper adaptors in my shop.
Bill
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
Quote from: CutterBill on March 13, 2016, 10:20:42 AM
Bill
I can bring '86 forks and wheel, the Blue dots you will need source on your own. The salvage value of the metal might be worth it...
CutterBill
Quote from: FJmonkey on March 13, 2016, 10:40:50 AM
I can bring '86 forks and wheel, the Blue dots you will need source on your own....
I don't need blue dot calipers for my bike.  At least, I don't think I do.
Guess I should have said... if someone brings me forks and calipers, I can make adaptors for anyone who needs them.
Current Stable:
FJ1100
FJ1200 (4)
2015 Super Tenere
2002 Honda Goldwing
