FJ1200 ABS '91 from damp shed - Moditus attack story
Started by MOTOMYSZOR, March 01, 2016, 12:01:59 PM
MOTOMYSZOR
It was September 2014 when I decided that I will buy my first Yamaha.
She was in pretty bad condition: rust, dust and spider webs. But despite that appearance, after few minutes I got strange feeling that She can be nice bike for me.
Now I know that was the moment when moditus bug jumped straight into my brain  :crazy:
I have spent hours on carburettors an valve regulations, cleaning and checking all bike from back to front:
That is first photo where my FJ looks decent:
And then I found FJowners forum and section: MODIFICATION .....
And that was beginning of MODITUS ATTACK  :crazy: :crazy: :crazy: :wacko2: :wacko2:
Previous owner installed few extras:
- full set of Givi boxes
- rear shock absorber Hagon (red spring) + progressive front
- engine bars
And from that time I added few other......
A fork brace will stiffen the forks up and reduce the chances of your front fender tabs breaking.
MOTOMYSZOR
First my ,,small" mods:
Front braided brake lines and FZ8 gold brake callipers:
Engine temperature meter and volt meter:
14 mm clutch MC from FJR and brake MC from Fazer 600:
I also installed CBR mirrors, Ignition coils relay, GPS holder.....
MOTOMYSZOR
In middle of 2015 I swapped front rim for FZR 1000 rim.
This is list what was needed for my ABS model:
- front FZR1000 wheel - in my case with 17 mm axle
- set of brake discs - can be from various models like non-ABS FJ or many other 298 mm discs
- 6203 LHA Ball Bearing.  Size 15x40x12
- non-ABS 15mm inner spacer. Spacer from my ABS model is to short.
- non-ABS collar spacer (between fork and wheel bearing) because ABS one is to short again.
- FJ1200 15mm axle and speedo driver.
MOTOMYSZOR
And then the biggest mod: rear wheel, brake system and swingarm from Fazer1000:
Together with Delkevic exhaust rear end looks nice:
Karol, absolutely wonderful job :good2:
You should be proud....marvelous!
You will notice the improvement with modern 17" tires along with those R-1 brakes
Cheers...again well done!
MOTOMYSZOR
I started work on a new mod: gear indicator
So far I upgraded neutral gear sensor.
First I had to find specific points on switch where should I drill.
For  create imprints, I used plasticine:
Important part is to use guide screws:
As a connectors I used M3 allen grub screws:
top:
From inside:
First fittings:
I used conductivity meter to regulate, how deep those screws should be screwed to get good contact with gear shaft. On end I used glue gun to seal everything...
half job done :)
MOTOMYSZOR
MOTOMYSZOR
Time for front suspension upgrade and rebuild......
Today I received Race Tech springs and emulators.
And already i have problem:
As You can see on photo original RT washer is small enough to cover most of oil flow area in emulator..... Is that OK?
And one more question: I got yellow and blue springs for emulator: which ones suit better for FJ?
MOTOMYSZOR
It is too late to edit post.....
I discovered that no washer is used under spring......  :blush:
But still..... spring has this same size as washer and will greatly block oil flow....
ct7088
There is a calculator according to your weight on Race Tech FJ 1200 page. 190 lbs gives a answer of .934kg/mm with the suggestion to use the number that is closest which is .95kg/mm
Chris
Chris
MOTOMYSZOR
I Have big problem.....
Because Hagon progressive spring was so hard suspension worked only on half way...... the upper fork part was unused and rusted...... When I touched it chrome just fell off.....
So if now suspension will travel all length available (150mm) seal will last for few Kilometres.....
I don't know what to do now...... Or actually I know. Have to buy forks in good condition.....
MOTOMYSZOR
I found front suspension from 95 FJ1200 in really good condition on eBay.... and already I got everything done.  :rofl:
My setup:
-Race Tech springs 0,95 kg/mm
-Fork Oil 15W motul
-Oil level - 130mm ( with emulators in)
-15mm preload
I used yellow (hard) springs in emulators, set at 2 turns in. And for me it is to hard......
When I will have a time I will try blue springs and lower oil level (150mm)
MOTOMYSZOR
I think I finished front upgrade.
Final setup:
- emulators with blue springs. 2 turns in
-Fork Oil 15W motul
-Oil level - 140mm ( with emulators in)
-20mm preload
Now I have full control on every corner or roundabout. I notice less vibration while riding. And my chicken strips are smaller now:
MOTOMYSZOR
After few situations when me or my friends have heard: SORRY..... I DID NOT SEE YOU I decided.....
Time for CHRISTMAS TREE mod..... I don't care about how it looks any more. I want to be visible....
First auxiliary lights, I used pair of 125W CREE lights:
125W CREE LED lights
To install them I used bike handle mount:
Bike handlebar mount
I mount them on engine protectors:
Part two:
emergency flash lights - I use them in heavy traffic and on motorway when somebody blocking my lane.
After huge trouble with finding suitable space I installed them under mirrors:
And to switch them on and off I installed this:
I am  very happy with those add ons.....
