XJR levers for FJ from China
Started by Vilike, February 08, 2016, 02:31:03 AM
Vilike
Hi guys,
  i just found these pair of brake+clutch levers for XJR on Ebay, and i wanna ask you about your opinions. I would replace the stock levers on my '86 FJ-1200 1TX with this stuff. Its really cheap, so i would purchase it immidiatly but i don't know what it can take you know...
Here:
http://www.ebay.com/itm/151950845212?item=151950845212&viewitem=&vxp=mtr
FJ1200 1TX '1986
FJ1200 3CW '1988
FZR1000 Exup 3LE '1991
4everFJ
I wouldn't...
They state that it is for an XJR1300, but at the same time they write: "Fit on most brand 125c.c. to 400 c.c."
Looks too cheap. The brake system is the one thing you shouldn't go cheap on.
1985 - Yamaha FJ1100 36Y
1978 - Yamaha SR500
1983 - Kawasaki GPZ550 (sold)
1977 - Kawasaki Z400 (sold)
Vilike
Yes, thats why i asked it. I don't want to get a new set of scrap on my FJ...
FJ1200 1TX '1986
FJ1200 3CW '1988
They're probably OK.
The build quality may be sloppy, and the finish is likely to not be up to Brembo or Aisin standards.
And, you aren't likely to find any replacement parts like levers or seals or switches if you need them.
Still, if you're willing to gamble and get a set to at least check out, its not a lot of money.
Frankly, I'd be more concerned at the low feedback count even though its all positive.
And, as its Chinese New Year, your order won't be picked, packed, or shipped for about a week.
Vilike
Thanx Arnie.
I had to think about that. I got a really experienced bike mechanic friend here in my town and he owns an FJ 1100 too. He said he will purchase one of these by all means. So its up to me, and i say ill try it.
Really cheap, so why not ?   :pardon:
FJ1200 1TX '1986
FJ1200 3CW '1988
Quote from: Vilike on February 08, 2016, 04:28:16 PM
....... Really cheap, so why not ?   :pardon:
The clutch m/c does not concern me....but your front brakes are kinda important.
With the Chineese front brake m/c, worst case, in the (unlikely?) event of a seal failure, I guess you always have your back brake.
Report back, let us know what you think....be careful!
groome
ive tried getting some adjustable levers and not had much luck either been poor quality or poor fit still on the hunt. if you do go for these keep us updated on them  :good2:
89  fj12 banshee
Normal = BORING
Bones
I bought a Chinese 14mm master cylinder a couple of years ago for a bit over $20.00, installed it and filled it with brake fluid only to have it leak out the bore without even pumping the lever.  Couldn't be bothered sending it back because I'd probably cost more than it was worth and just put it down to you get what you pay for.
Save your coin and buy something decent, I recently fitted one from an fjr1300, looks the same as standard but with an adjustable handle and heaps better feel.
93 fj1200
79 suzuki gt250x7
Vilike
Thanks guys, i will report you what i experienced about the stuff. I will set it up with care...
  :i_am_so_happy:
FJ1200 1TX '1986
FJ1200 3CW '1988
hein
Call me a skeptic if you want but I have a hard time believing that a pair of m/c suitable for 125 to 400cc. bike are also suitable for a 1300 FJR. Most 125 to 400cc scooters dirt bikes and street bikes have small single disc front brakes and rarely have hydraulic clutches. The larger double front discs and double 4 piston calipers on the 1300 FJR would require a larger bore brake m/c than the small displacement bikes. No mention is made of the bore sizes of either m\c and the only size reference is regarding handlebar size 7\8 common to 99.9% of all bikes. Check with the vendor regarding bore size before wasting money.
Hein.
Charlie-brm
Quote from: Bones on February 09, 2016, 01:19:10 AM
That reminds me of my requiring a replacement master brake cylinder for my old beater of a car. OEM from GM was several hundred $ more than what the mechanic could get that was made in China.* But he said several of those were leaking while the car was still up on the hoist. i.e. not just leaking from a loose fit to the rest of the system, they were bad out of the box.*
There are times one can get away with gambling on cheap goodies. Hell, I order my share of offshore for things where I'm hacking fun gizmos. Vehicle brakes wouldn't be one of those applications.
*This is not a blanket knock against made in China, just the stuff to be put under mechanical stress that's "too good to be true."
1979 XS750SF - 2005 to 2012
Nova
Quote from: Charlie-brm on February 12, 2016, 01:59:44 PM
The thing to remember about China is you can find someone there who will make whatever you want at whatever price point you want. The quality of the end result will reflect how much you are willing to pay to have them make it. So, you could contract a manufacturer to make something as good or even better than the original. But the price will be relatively the same or higher. Since the whole point is they want a product at a much lower price point and be able to pocket the difference that defeats the purpose, so they negotiate a much cheaper production cost and a corresponding much lower quality.
So... nobody is knocking Chinese manufacturing per say... just that the type of thinks that generally come from China are going to be cheap knock offs because that is exactly what the importer wants them to make.
Funny how history repeats itself..... I remember having this same discussion except the country was Japan.
Life is a funny old dog.
Charlie-brm
Quote from: Pat Conlon on February 12, 2016, 07:20:33 PM
I think this board has lots of us that go that far back. I remember the "disgrace" when U.S. stereo companies moved their manufacturing to Japan. Didn't matter that all the tech engineering, specs, etc. were still done from the U.S.
Korea paid its dues with automobile quality. They all have their passage of acceptability. I live in Canada and drive a Hyundai Elantra assembled in Alabama, containing parts machined in Canada. I love it, gets lots of compliments. Did I buy a foreign car?
Vilike
Well i received the levers just a week after i purchased.
It was really fast from China to Hungary.
Nice stuff. Simple, fine machining, bore dimensions are as same as on the stock FJ. Looks massive enough, nothing is wobbling or creaking. Damn i will try it. You can not buy things like that in Hungary for a so low price like this.
FJ1200 1TX '1986
FJ1200 3CW '1988
