gear box
Started by willismcclean, February 07, 2016, 09:14:57 PM
when i select first gear there is aloud rattleing but clutch is working ok i think and bike moves ok,,, any ideas
gear box
0 (0%)
heavy rattles when first gear is selected
1 (100%)
Total Members Voted: 1
Voting closed: February 17, 2016, 09:14:57 PM
willismcclean
when I select first gear  theres a loud rattleing
Does this rattling happen for a short moment or is it continuous while in 1st gear? Are you sure this an FJ and not a Ducati? Is the rattle soft or a sharp? Does it sound metallic or something else?
willismcclean
it has only started this today, I was only moving the bike in  my yard  I may learn more tomorrow,,the sound is metallic but not a sharp sound
moparman70
only time I have heard a rattling sound on my fJ was when something was broken inside --- it was on a side stand when i heard the noise -- 2 miles later pulling into my buddies place it locked up and threw  me ( low speed - no issues other than that motor was put aside ) --
but if yours is running ok --- well I would take the clutch cover over and do an inspection -- replace the plates if you deem necessary because its off --- and hope you don't have the same issue I had ( PS -- my problem was just after a very very hard time just trying to get the bike into first gear so something went causing the catastrophic failure
stevec
Neoday2
I it a rattle or a rumble?  My FJ makes a sound similar to some rocks tumbling around when letting out the clutch in first gear.  I guess I haven't given it much thought, another buddies Yamaha did that and the PO said it was not a new sound for the bike.  2K miles later and no issues...
Maybe get a recording of the sound and share it here?
IceFJ
Starter chain rattle possibly ??
Yamaha FJ1200 `86 (current)
Honda XR400R `00 (current)
Kawasaki GPZ550 `82
Horex 350 `52
Jawa 350
Honda XL500 `82
Honda XL500 `80
Honda SS50 `75
