Question about handle bars
Started by Vilike, November 21, 2015, 08:20:17 AM
Vilike
Hi guys,
my '86-er 1TX is almost ready to run after a 10 months maintenace. Repainting the frame, all covers (stock pattern !)
tank,  exhaust, etc...
So i decided to change the handle bars too. I see the two stock bars could be changed with each other, so are those two bars fit at the front cover if i turn the steering ? Or they are cought in the cover ?
FJ1200 1TX '1986
FJ1200 3CW '1988
FZR1000 Exup 3LE '1991
Quote from: Vilike on November 21, 2015, 08:20:17 AMHi guys,
tank,  exhaust, etc...   So i decided to change the handle bars too.
Vilike,
You can buy a handlebar adapter kit for the FJ that works with many handlebars.
http://www.bikermart.co.uk/proddetail.asp?prod=240-10205-2nd
I do not understand what you ask, in the second part.
Vilike
Thanx Red.
I mean i want to put the left bar to the right side and then the right bar to the left. Just fits, i tried. So the bar would be more straight and tourer-like. But does it fit by the fairing cover when turning ?
FJ1200 1TX '1986
FJ1200 3CW '1988
No, it will limit range of movement ..
Try some handlebar risers instead. Or go with a handlebar kit.
Vilike
Thank you Mark.
Well, then i will make a custom stuff.  :good2:
FJ1200 1TX '1986
FJ1200 3CW '1988
Quote from: Vilike on November 22, 2015, 02:54:20 AMThank you Mark.
Vilike,
There are a number of handlebar risers and adapters for the FJ.  Do some searching on the Internet, and with your local bike clubs to see what is available.  Your search will give you good ideas for your custom-made bike parts.
Here are the two handlebar options available from RPM.
RPM Handle Bar Riser
Spiegler LSL Handlebar Conversion Kit
Don't forget, there is a 10% off sale this weekend: http://www.fjowners.com/index.php?topic=69.msg148969#msg148969
