Caliper mounts for 320 mm rotor
Started by sbikebee, November 15, 2015, 08:54:08 PM
sbikebee
Anybody have a drawing, blueprint, program for making the off set caliper mounts to use on standard FJ forks when using 320mm rotors? Or maybe a set of the plates to sell? Thanks.
Bee Johnson
Bee/CNU
There may be a member or 2 that have swapped in the early FZR forks and wheel that allows the use of the 320mm rotors.
I do not believe that there is a bracket that is readily available for OEM FJ forks and 320mm rotors.
There are brackets available for the 1100 and 1TX 1200 forks that allow the use of 298mm rotors, the 17" OEM FJ wheel and Blue/Gold dot calipers. This link is from a company listed on a Vmax forum. These brackets WILL work on the early FJ forks. http://www.exactrep.com/acatalog/Front-Hanger-Brackets--pair--12B.html#SID=22
