Patience is a virtue, replacing clutch slave cylinder
Started by ELIMINATOR, November 13, 2015, 03:42:26 PM
ELIMINATOR
Replaced this last Friday, no garage,  :cray: I've replaced the seals in the old unit twice, so I know what a pig bleeding the system is.left the clutch lever tied back for two days. Still no pressure, dark evenings and rain stopped play.This afternoon, as I finish early, out came the tools, off came the master cylinder cover, decided to tug the clutch the hose hear to the slave cylinder, bubbles galore rose to the master cylinder. 5 minutes later, full pressure attained..... be patient..... :yahoo: :yahoo:
BMW 1150GS
Moto Guzzi California 3
Kind of like the cream rising to the top. Another happy ending...  :scratch_one-s_head:
Once again, tying the lever to the bar does NOTHING!  It's the waiting that allows to bubbles to rise in the system that makes it work.
PAITENCE is the best tool in the hydraulic bleeding tool kit
Naaaaa, the best tool for hydraulic bleeding is a MityVac.
Timbox
Quote from: Pat Conlon on November 15, 2015, 12:46:46 AM
Once you try that Vac or other type bleeder Vac, you will wonder what took you so long to get one.  Love it for one person jobs!!
1986 Fj1200
2003 Bandit 1200S
2009 KLR650
twangin4u
Yes. Hand vacuum pump (bleeder) is cake. Although I've booked it more than a few times by just pumping the lever and flicking or tapping on the line with a box end wrench till all the air rose to the resivour. Takes 15 mins.
ELIMINATOR
Got one now, had to bleed the linked brakes on my Moto Guzzi California 3, after replacing the piston in the master cylinder. :good2:
BMW 1150GS
The way to go is a vacuum brake bleeder kit. Brake/clutch bleeding takes 5 minutes. A must have tool.
balky1
I've read a lot of posts here saying you guys are having a lot of trouble bleeding the clutch. I wonder if I was just lucky or what since I bled it in less then 5 minutes, old-fashioned way. I filled the slave with fluid to the top with a syringe at first (with removed bleed nipple), put the nipple on, filled the reservoir and just pumped. Over in a couple of minutes.
Was I just lucky?
FJ 1100, 1985, sold
FJR 1300, 2009
krusty
No, not lucky. The old fashioned way works if done right. I've lost count count of the number of times I've bled brakes, car and bike, and the only time I had a problem was when I refitted my FJ11 calipers upside down.
84 FJ1100 x 2
85 FJ1100
89 GL1500
60 Colleda 250TA x 3
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
oldktmdude
Quote from: Pat Conlon on December 01, 2016, 05:14:15 PM
Upside down? How can you do that?
I would assume, left on right side and right on left side.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
krusty
84 FJ1100 x 2
85 FJ1100
89 GL1500
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
bartzld
I must have been so lucky. Yesterday I replaced the old clutch master with a FJR1300 master. I removed the old master, placed the new one, filled it with fluid before connecting the hose. Then it took 5 minutes of bleeding and it worked perfectly.
