Slight miss
Started by Jeff0308, October 30, 2015, 06:31:24 PM
Jeff0308
For a while now I've been noticing a slight miss like a tight / burnt valve just above idle. It's ever so slight but I notice it more when I've got my helmut on and I just go slightly above idle. Seems to smooth out however it doesn't appear to effect the running other than its uneasy idle. Thought maybe burning valve runs to smooth and last compression test was minimal difference. Not certain when shims were done last. What's the engine characteristics of shims requiring attention?
Over time the valves get tight. This happens as the valves recede on the valve seats causing the shim/cam clearance to get smaller.
If left alone and not adjusted, the valves will not seat causing a loss of compression.
This will cause a loss of power. The bike will not pull strongly. The FJ's have an abundance of torque so on our bikes you can lose some and not notice.
This loss is gradual and gets progressively worse, when riding on the street many owners don't notice it right away until damage done to the valves and seats.
Check your valve clearances. If tight, fix them.
That said, I don't this is causing your slight miss, especially if your (hot) compression tested fine.
oldktmdude
   Jeff, the first thing I'd check is the spark plugs. They can often misfire at lower revs and then smooth out as revs increase. It's also easy and cheap to do. Check the simple things first.  Pete. :i_am_so_happy:
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
What do the plugs look like?
If one or more are black then it might be as simple as replacing the O-rings on the carb needle seats.
Also, Pete has a good point.  A cracked plug will cause a low RPM miss.
Jeff0308
Plugs are realatively new. Done about 2000km. However I haven't removed them since to check. That's next. Might do it with valve shim check. Or sooner
