1984 FJ1100 Rear Suspension.
Started by krusty, September 11, 2015, 05:00:32 AM
krusty
Is there such a thing as an overhaul kit for 84 1100 rear suspension. My 84 has wear in the linkages and I would like to have everything I need before I tear it down. Rear shock working well.
84 FJ1100 x 2
85 FJ1100
89 GL1500
60 Colleda 250TA x 3
63 Suzuki MD50
77 DT125E
77 DT175E
78 DT175F
79 DT250F
mr blackstock
G'day,
When I did my rear linkages I just ordered what I needed from referring to a parts diagram. Be sure to order off boats Yamaha parts from the states. Even with the low dollar it will be heaps less than local dealers.
Also check Randy's site, not sure if he carries suspension linkages though.
Cheers, gareth
Yamaha FJ1100 1985
mr blackstock
I found this in my pics, an interesting comparison between sellers, prices are in AUD.  From this you should be able to assemble all the bits you need.  Research the forum as some guys used needle bearings instead in some places.
Yamaha FJ1100 1985
