Lost the damn choke knob screw...
Started by JPaganel, September 08, 2015, 02:43:46 PM
JPaganel
The knob came off in my hand.  Apparently the screw vibrated loose and fell out.
It's what, an M3, or some such thing?
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Quote from: JPaganel on September 08, 2015, 02:43:46 PM
M3 is way too big... I have a few kicking around, I will mail you one. Off to the garage to find that little bag with little choke knob screws....
In the mean time, use a large paper clip as a pull tab till the screw arrives...
anson45
I may have used a dab of thread locker, I hope not, but I definitely wrapped a thin piece of black tape around the knob securing the screw.
Anson
1981 XS650H
1983 XVZ1200 (original owner)
A dab of blue Locktite is no problem. Good idea on the tape!
JPaganel
Found the thread size. It's M2.5.
My local Ace Hardware had that size, but they are about three times as long as the original and the head is a slot, not a Phillips.
1993 FJ1200 ABS
Quote from: JPaganel on September 08, 2015, 09:50:45 PM
Check your mail box in a few days....
JPaganel
Quote from: FJmonkey on September 08, 2015, 09:52:06 PM
You are quickly becoming a favored supplier. :)
Monkey, the FJCrack dealer...  :blum1:
1993 FJ1200 ABS
For those that don't have an Ace hardware in their local, or when FJmonkey runs out of his supply. Partzilla has the correct screw for the choke knob. It is located on the 1986 FZ750 parts list.
http://www.partzilla.com/parts/detail/yamaha/YP-90149-03132-00.html
I recently had mine get loose and fall out during a ride. Lost the screw, knob and small cover. I had a knob and cover in my spare parts, but had to order a screw. I ordered 3 so I have a couple of spares.
markmartin
Quote
Good Karma
For those that are tired of losing the screw/knob, consider using a small spring hitch pin to hold the knob on.
Makes removal simpler also
FeralRdr
