GIVI Tanklock system on '84 1100
Started by Dads_FJ, August 22, 2015, 08:50:50 PM
Just passing along my tankbag mod using the GIVI tanklock system on my '84
Using grease on my drill bits and then using this with some goop for sealing:
http://www.harborfreight.com/45-piece-threaded-insert-riveter-kit-1210.html
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
'43 BSA WM20
Looks pretty good there.
Since you'll be keeping this FJ for eternity, you don't have to worry overmuch about resale.
It must have been difficult to drill the first hole though.
Kinda like the 1" hole I cut in my brand new car to install an antenna 40 some years ago.
You got that right Arnie, you don't know how many times I double-checked my work befor drilling.  Once that first whole was drilled I knew there's no going back.
'06 KTM 200XC
'43 BSA WM20
Now that is just excellent!
100% perfect solution. As the original user of tanklock bags here, it still impresses me every time I use it. I like it so much I have two bags, the smaller semi hard shell bag probably getting the most use.
Mine have done many miles and even been forcibly knocked off a few times with fall overs without any damage to the locking mechanism.
I periodically check the integrity of the mount and it shows no sign of loosening off with use, you'll love it.
Well done.
I have the same bag and mine has sagged down in the back and is rubbing my paint. Been thinking of maybe putting a thin piece of stainless or something under it. To hold it up but haven't gotten a round 2it yet.
But other than the sagging. I love it. Got a ring on all of the bikes so I can use the same bag on any bike.
Quote from: giantkiller on August 22, 2015, 11:11:52 PM
Yeah Dan, I had the same problem. Short term fix was a bit of duct tape. I then made a spacer plate just thick enough to raise it so it didn't touch, then it sagged a bit more. I could have made a thicker plate but felt I would chasing my tail.
What I had planned to do, and will get around to doing, was cut a piece of 16mm marine ply to shape, stick black vinyl to it and glue it to the bottom of the inside of the bag. You could even put a few screws and flat washers or staples (SS) from the underside to be sure.
About this time I realised I don't actually carry much in my tank bag and had never even expanded it and it was too floppy to operate the zip one handed while riding, so I bought this and have used it ever since.
It's not quite as big as it looks in the photo but carries all I need.
If I buy a new camera I will go back to the other bag for trips, after I fix the base.
I notice the newer bags of that model are slightly different in design, perhaps they've fixed it now.
I use mine alot. That's not a bad idea about screws to pull it up. Might look into the smaller one.
