Back from the wreckers.
Started by JPaganel, August 21, 2015, 06:03:35 PM
JPaganel
The insurance came through. They offered $2100, which is KBB value on the nose, and $500 to buy it back. So, I bought it back.
Today I picked it up from the wrecking yard. It started up right away, and I rode it home.  :yahoo:
The losses are right hand scoop, crankshaft cover, whale tail, left turn signal, seat cover, right mirror. Left side fairing is cracked, but fixable. Main fairing also cracked, might be fixable too. Also, the tiedown bracket on the left side is gone, and right brake lever is bent.
For some reason, it leaks gas when it runs. Didn't do that before the hit.
So, looks like the bike might be salvageable.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Try tapping on the float bowls. Sometimes they hang up when they get laid down.
Urban_Legend
Glad to here that it's fixable.  Check that the forks aren't bent too.
Mark
Mark
My Baby (Sparkles)
84 FJ1100/1200 motor
84 FJ1100 - Project bike.
Quote from: giantkiller on August 21, 2015, 06:31:28 PM
Yep, very common if they've been on their side and not permanent.  Giant killers advice should fix it or even just a big rev through the gears.
Quote from: JPaganel on August 21, 2015, 06:03:35 PM
With the bike on its side you likely have stirred up some crud (as already posted) and it is affecting the needles and seats. I had a zero speed tip over a few months ago and my FJ started leaking. I drained the carb bowls and started the bike. The fuel flow is at max since the bowls are empty and washes out the crud every time.
A stuck float OR crud in the seats can both cause the overflow.  In the latter case, the Monkey's on the ball (on the vine?).  In the case of a stuck float, I rode mine off a curb and the jostling freed it right up!   :good2:
Glad you got it back and still runs. sounds like all cosmetic stuff and you are good to go.  :good2:
JPaganel
Quote from: Urban_Legend on August 21, 2015, 06:45:51 PM
Mark
They don't look bent. Is there something specific to do to check them?
1993 FJ1200 ABS
Urban_Legend
You would know when you ride it. It just wouldn't feel right.
Mark
My Baby (Sparkles)
If you want to be sure....
Take the forks out of the triples and place a straight edge inline with the fork tube at several places around the circumference of the tube.
Or, if you've got a large plate of glass, try rolling the fork tube on the glass.
Either of these methods will let you know if they're bent.
Quote from: JPaganel on August 22, 2015, 07:52:09 AM
Mark
JPaganel
So, knocking on carbs got the leak to go away - it was a stuck float.
As to the forks...
The bike goes down the road straight and turns normal. No weird feels. However, it sort of looks to me visually like I have to steer left a bit to go straight. Is this a sign of bent forks? Or something else?
1993 FJ1200 ABS
Take your forks off, place the stanchion tubes on 2 supports, now roll the forks, do they wobble?
That is called, checking the run out. If either tubes show a wobble, replace them or send them out to be straightened.
oldktmdude
   Your forks may be twisted out of alignment. Raise the front end off the ground enough to take the weight but not enough to lift it clear. Loosen all the triple clamp bolts and front axle. Give it all a good shake from side to side. Pull on the front brake lever a couple of times. Tighten axle first and then the triple clamp bolts. Make sure you torque these to spec's. Test ride to check if this has made any difference. Worth a shot doing this before you pull the forks to check for any signs of being bent.
Regards, Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
Troyskie
The handle bars have a few degrees of adjustment front and back.
One of my handlebars is slightly bent (PO highside) and I had the slightly turning feeling till I adjusted them.
Out on the edge of things now, could the foot pegs be bent? One of mine is bent (from above), and it does alter my sitting position slightly.
Troy
