Fj 1100 brake disc alternatives
Started by 4everFJ, August 21, 2015, 01:05:48 PM
4everFJ
My discs are under the wear limit  :negative:
What discs from other bikes fit on the FJ 1100?
Thanks.
1985 - Yamaha FJ1100 36Y
1978 - Yamaha SR500
1983 - Kawasaki GPZ550 (sold)
1977 - Kawasaki Z400 (sold)
4everFJ
Thank you, but I am located in Europe and with shipping, tax, etc.. it will unfortunately be too expensive  :sorry:
1978 - Yamaha SR500
5 min using the search function yielded some good results... I am done searching, if you want more info, give the search option a try.
Here is a thread that mentions the V-Max rotors being the same size.
http://www.fjowners.com/index.php?topic=13762.msg138796#msg138796
Another good read from Pat
http://www.fjowners.com/index.php?topic=8623.msg80270#msg80270
And another one on the Chinese wave rotors, I use the Arashi and I really like them.
http://www.fjowners.com/index.php?topic=8937.0
Depends if you are looking to upgrade or just keep rolling on the stock rotors.
The rear rotor is the same as the fronts for the 1100 and early 1200 FJs until 89 . So you can put the stock rotors on from someone who upgraded in your area hopefully .
4everFJ
Thanks a lot for all your help. Much appreciated  :good2:
1978 - Yamaha SR500
