17'' rear gixxer wheel
Started by scotiafj, July 30, 2015, 02:43:50 PM
scotiafj
 :hi: I will be doing the 17'' gixxer wheel swap soon as Ive got all the parts to do it  :good2: I purchased a part worn 150/70/17 avon 3d-xm that had done only 500 miles so it was barely run in :) would I need to fit shorter dog bones ?? seeing as most folk that do the swap fit shorter ones or would it be fine to run the wheel with that size of tyre ? cheers Scotia
Sabre093
What are you still looking for...I have a 91 GSXR rear brake assembly (Hangar,Caliper and the correct stay)..I ended up with 2 when doing mine.
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
1984 Honda Nighthawk S 750
1982 Honda Nighthawk 450
the fan
Quote from: scotiafj on July 30, 2015, 02:43:50 PM
What is the width of the wheel? A 150/70 is too narrow for a 5.5" wheel, but will work well with 4.5 and 5.0 wide wheels.
scotiafj
Hi Ive got every thing to do the swap ie wheel,brake torque arm ,disc caliper etc was jus wondering if it would be ok not fitting shorter dogbones on it ,, ??? seeing as it has a higher profile tyre on as most folk fit a 60 or a 55 profile 17'' tyre...and they fit shorter dogs to bring the swingarm down to compensate for the lower sidewalls
scotiafj
89 gixxer 1100 4.5 :) it fits a treat on the rim :)
Sabre093
I got a 170/60/17 Contimotion on my 89 GSXR 1100 rim....It works great!
2009 FJR 1300
1992 FJ 1200
1987 FJ 1200 Sold
1986 FJ 1200 Sold
1985 Venture Royale
1976 GoldWing
1986 FZ 750
1986 GPZ 900
No, you don't have to fit shorter dog bones. The difference in OD between the two wheels is not significant (bigger wheel/lower tyre)
The main reason for fitting shorter dog bones is to improve handling and not directly related to the wheel swap.
