Carbs
Started by Cash Dereszynski, July 23, 2015, 05:43:40 PM
Cash Dereszynski
hello
Back at it. Ordered emultion tubes, I hope this is it !
Cash
Fuck it,let's ride.
Make sure you get the right e tubes for your FJ1100 carbs.
The e tubes for the early carbs with the flat bottom slides are different than the e tubes used on the later FJ1200 carbs with the curved bottom slides.
Randy @ RPM knows this, all other shops (like Factory Pro) do not.  If you got the e tubes from Randy, you're gonna be ok.
Cash Dereszynski
It didn't work. still nothing after idle.
I give up . Saving up for complete RPM carb set.
Cash
Fuck it,let's ride.
Before you buy a new set, first send your carb's to Randy and ask his opinion.
Cash Dereszynski
Carbs are buggered by me and dynojet mods.
Fuck it,let's ride.
Quote from: Cash Dereszynski on November 06, 2015, 02:46:55 PM
Do you mean they are beyond repair? Or are you planning to send them to RPM for some carb Mojo? If you still need to ride it I can loan you my carbs off my '86. They are set too lean for open pipes but can get you by for a few weeks.
Cash Dereszynski
The last attempt was to install main nozzle and pilot jets .Wrong main nozzles modified(butchered) pilot jets mangled then tried to extract with ez outs mangled more,completely
drilled out #2 carb pilot can't change the others too buggered to back them out. Reassembled as best I could:(   The bike starts and idles even to a RPM of about 3k on choke and at moments even higher. I'm convinced its a carb issue not electrical or coils. So ....(1) a used set of carbs , (2) a new set of carbs(RPM) ,(3) ship my carbs to RPM to undo the dynojet and my buggery , (4) New fuel injection complete from late model FJ , (5) part it out buy a Prius.
What say you Forum ?
Cash
PS in escrow for a place in Palm Springs just off Hwy 74 besides all that other stuff!!!
Fuck it,let's ride.
Send them to RPM and get a quote... Decide after the quote...
I would lay low for a good used set of carbs and rebuild. Problem is making sure that a used set from "flea bay" as an example is not buggered up. Shop carefully.  Contact Randy he might have a used set for sale or other options.  Perhaps if just one carb is buggered up you might get by with buying a single used carb from a parts set of carbs.  Step 1: call RPM.
Originally my bike was set up with "Dyno Junk" jets, needles and springs.  I converted them back to all Mikuni parts and have never looked back.
I might have some spare parts from my original '86 carbs....
If it's off Hwy 74 then that would not be in Palm Springs, but in Palm Desert, so welcome neighbor.
If you've never ridden a bike on Hwy 74 you're in for a treat. The road has a fresh overlay, smooth as silk.
Back to the carbs: Send them to Randy, see if he can save them. He has lots and lots of parts...lots.
Worse case: find a FleaBay set, then send those to Randy. Don't fuck up another set.
copper
what does the forum say, the same thing many including me told you back in April http://www.fjowners.com/index.php?topic=13579.msg137110#msg137110
congrats on the house
Quote from: copper on November 07, 2015, 07:13:23 PM
Oh the memories, thanks for posting those up. I remember your disbelief about the dirt in the carbs when you sent them to me the second time; quite a difference from the stock filter to those K&N's. Glad you are happy with the RPM pod filters and I assure you they will not be that dirty the next time.
Then there is the link to Randy's (not a lib) carbs too...those were probably the worst set of carbs I have ever received and was able to resurrect.
Cash, if you want to send me what you have and we can see if they can be salvaged. Please send me the original e-tubes and all of the other original parts you might still have as well.
Quote from: racerrad8 on November 07, 2015, 07:28:35 PM
But hey, that was the way they were when I got 'em...  :pardon:
JPaganel
Quote from: Cash Dereszynski on November 07, 2015, 04:55:22 PM
Sadly, no such thing. FJ never got FI.
XJR eventually did, but you are in US, so no XJR anything for you. Plus, a complete XJR FI system wouldn't be particularly cheap.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
