1985 Yamaha FJ600 carb question
Started by Cbraun, July 15, 2015, 09:23:55 PM
Cbraun
I have an 85' Yamaha fj600 and the carbs are missing some parts for the fuel mixture screw. and i cant seem to find much on it. I'm looking for the washers and O-rings for them or at least part numbers for these pieces. Any help would be greatly appreciated as i'm coming up with almost nothing.
85 FJ600
Quote from: Cbraun on July 15, 2015, 09:23:55 PM
The carbs may share the same parts as our 1100/1200 engines. Give Randy a call, he is a Yamaha dealer and is very helpful to us in the FJ world...
www.rpmracingca.com
hawkaholic37
Welcome! I'm glad you found us!
Everyone, this is my new friend from another forum :)
2004 Suzuki SV650S    Current
1999 Honda EX400    Past
1971 Suzuki TS250    Past
1982 Honda XR250R    Past
1985 Honda VF700S Sabre    Past
1981 Honda CM400    Past
1986 Honda Spree (Weehawwww!!!)    Past
1978 Suzuki PE175    Past
Cbraun
85 FJ600
Cbraun
Whats the Difference between the Fj's and the XJ's?  And are there any differences on the top end of a Mikuni BS36/ CV Carb that Yamaha and Suzuki Uses?
85 FJ600
JPaganel
Quote from: Cbraun on July 19, 2015, 10:21:18 AM
FJ600 was XJ600 outside US. It shares very little aside from styling with the FJ1200. Where the 1200 has a perimeter frame, the 600 has a conventional backbone frame, like the rest of the XJ series. It's closest relatives are XJ550 and Seca II. The motor is essentially the same design, but smaller. Mikuni BS series carbs of the same size are generally the same on different bikes, but can have different jets and needles.
In their infinite wisdom Yamaha did not list the pilot screw as a separate part for the FJ600. Even when they do list them, it's not separate parts, but "pilot screw kit".  Mikuni carbs, if I remember right, can have two different kinds of pilot screws, the difference being the thread. One type is coarse thread, the other is fine thread. The pilot screw washers, springs, and o-rings most likely interchange with the other Mikuni BS series carbs, and so the ones Randy has should work.
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
JPaganel
I'm gonna be the guinea pig here.
I tried taking out the pilot screws out of the FJ600 rack and found one royally boogered up from the factory. I'm in the process of destructive removal.
I just ordered a set of new screws from Randy. They look right. Once I get them, I will measure them against the OE FJ600 screws and post the results. With any luck, I'll be letting Randy know to change the listing...
1993 FJ1200 ABS
JPaganel
Randy's pilot screws for the 1200 carbs fit the 600 carbs without issue. Buy with confidence.
1993 FJ1200 ABS
