3D Pen uses ABS
Started by Arnie, June 09, 2015, 02:15:31 AM
I have not purchased this unit, YET.
I think it would be a wonderfully easy way to repair ABS plastic items, like cracked or broken fairings.
Check it out here:  https://tinyurl.com/qb2auzt
I have purchased other items from this supplier and had no problems (except slow mail delivery)
Note: I do not have any financial or other connection to this seller
If you're going to buy this, use the coupon code: newus  to bring the price down to US$43.51 inc delivery.
Antonn3
Arnie, an issue I see with using this pen is that it doesn't heat up the substrate which would make for a better bond.. You would simply be adding the melted ABS on top of the cold repair. Unless you can use the tip to heat up the repair.  I simply use a soldering iron and scrap ABS pieces  and they hold up very well.
Tony
