Brake Discs
Started by homerfj1100, May 08, 2015, 01:21:09 PM
homerfj1100
I've found new discs for my 85 FJ11
Do I have to modify anything. They are solid, not vented like the originals. Thanks
Tony
Homerfj1100
If the rotors are a direct replacement for the OEM 16 inch front wheel, The rotors should be 280mm dia. they should bolt right up and work without any issues.
homerfj1100
Thankyou for the reply. Very kind. But the 'middle bit' seems not to be there if you know what I mean. they appear to have the holes in the right places. But you know...they look hollow. You never know with sellers whether they actually know what they are talking about.He wants 80 for 3 delivered. Ta v much.
Homerfj1100
Quote from: homerfj1100 on May 18, 2015, 05:34:17 PM
The original rotors were vented, this allowed air to pass between the two braking surfaces inside the rotor. Modern rotors for bikes are all solid (with holes drilled through the braking surface) now as far as I know. They need to have the same bolt pattern, same diameter, same offset and be of good quality. My original rotors were vented, now they look like this.
