steering stem bearings
Started by Kopfjaeger, January 12, 2010, 05:31:06 AM
Kopfjaeger
just curious if anyone knows the bearing numbers for the steering head as i wish to get a new set and dont want to go through yamaha, if i can get them at a bearing shop i know it will be cheaper and mine have a notch in the centre,  86 fj1200 1tx.
cheers in advance :good2:
ren-dog
Nachi Brand
Top E32005J
Bottom E32006J
Do you also need the bottom seal plate?
I remember the world before Workplace Health & Safety.
ren-dog
Kopfjaeger
LEGEND!!! yes probably will best do the whole lot thanks heaps i will try to get them this week, also try to make up a bearing puller, if i can i'll send pics and see if you want one, tried to amke one for my gpz just tapped the holes wrong and never got round to doing it. cheers again!  :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :biggrin: :dance2: :dance2: :dance2: :dance2: :dance2: :dance2: :dance2: :dance2: :dance2: :dance2: :dance2: :dance2: :dance2: :dance2: :dance2: :dance2: :dance2:
MyFirstNameIsPaul
I recommend the All Balls kit.  It comes with replacement dust seal and everything.
I just cut my old bearings out with a Dremel.  Hit it at an angle and didn't even as much as scratch the frame.
I also installed a zerk fitting so I never-ever have to take the stupid thing apart again.
FJSpringy
Quote from: MyFirstNameIsPaul on January 12, 2010, 12:22:00 PM
nipple sounds better to me, like " I am going to play with the nipple on my "--------" (insert appropriate word, bike, girlfriend etc)"   :lol:
I have kleptomania,
but when it gets bad,
I take something for it.
92 FJ1200
Kopfjaeger
nothing wrong with nipples, even better to lube up   :blum1: chuckles
candieandy
I work for Napa auto parts and we have the bearing in stock.
HAUI
What's the number for the bottom seal?
Quote from: pdxfj on January 31, 2010, 12:00:16 PM
Lower seal is a HONDA '79 GL1000 seal 53214-371-010
Was wondering if there was an "aftermarket" part number (i.e. not Honda, Yamaha) for the seal.
The bearing numbers above could be had just about anywhere (as Candieandy said).
Quote from: pdxfj on January 31, 2010, 07:53:37 PM
Garth, can't find a part no, but the dimensions are ID 31, OD 56, W 4......... I'm guessing these are all in mm.......found on this site:
http://74.125.153.132/search?q=cache:EsEcHWOIvYcJ:www.bikersoracle.com/vfr/forum/attachment.php%3Fattachmentid%3D5063%26d%3D1056667474+53214-371-010&cd=5&hl=en&ct=clnk&gl=au
candieandy
we dont have the  lower seal at napa, but the bearing are in stock at most napas.
HAUI
