Chain guard removal question... And yes, I'm embarrassed....
Started by wirehairs, April 02, 2015, 07:59:18 PM
wirehairs
How strange to see a screw tucked up against the muffler that's holding on the rear of the chain guard.  But OK.  I bought a 90 degree screwdriver to remove it.  But then that front one... really?  So it's embarrassing to ask, but is the only way to remove that front screw is to use a stubby phillips screwdriver blindly in there?  I mean, you can't see the screw so you are doing it blindly, and it's so tight in there, it's hard to get leverage on the screwdriver.  I don't know - I just have a hard time believing that Yamaha didn't design this differently.
I almost thought removing the battery box was needed, that's even crazier...
Quote from: wirehairs on April 02, 2015, 07:59:18 PM
Getting to it requires removing two screws that hold the front half of the rear fender. Access them from inside the rear fender area, 10MM hex head I think. The fender pops right out, then you have all kinds of room to work.
Time with Randy has all kinds of perks....
wirehairs
[/quote]
[/quote]
Ahhh....haha.  I'll try that tomorrow then; too late now.  But thanks a million!  Would of been nice for the manual to tell me that....
Quote from: wirehairs on April 02, 2015, 09:00:47 PM
Post up tomorrow then mate...
ken65
I tried to get mine off once aswell, thanks for the tip Mr Monkey..
Quote from: ken65 on April 02, 2015, 09:23:59 PM
I tried to get mine off once as well, thanks for the tip Mr Monkey..
I had a teacher...
I went the other way than a stubby screwdriver. I pulled the seat and used a Phillips screwdriver that has an 18" blade.
1990 FJ1300 (1297cc) Casper
Quote from: aviationfred on April 02, 2015, 10:07:04 PM
I've always just used a right angle PH.
Last time I was in the area I replaced the JIS screw with a bolt.
wirehairs
Quote from: movenon on April 02, 2015, 10:42:30 PM
I agree that's the best solution.
wirehairs
Great idea, but on the 93, there's no sight line through the plastic and junk that's above it.   :sorry:
Quote from: wirehairs on April 03, 2015, 12:16:11 PM
Bugger! Is it least easier to get at with the fender out of the way?
With abs it's easier to pull the swing arm... good time to service the linkage and pivot bearings.
Timmer
Hey, Thanks for that! I dicked around with it for 30 minutes and then realized that someone else had had to deal with this.  Thanks again!
balky1
I just used the pliers to unscrew it and screw it back in.  :rofl:
FJ 1100, 1985, sold
FJR 1300, 2009
