GSXR sprocket???
Started by Motorheaddad, January 10, 2015, 05:11:07 PM
Motorheaddad
Ok, so I'm shopping for a GSXR 38t sprocket for my rear wheel mod. I have a 92 GSXR 1100 rear wheel. Does anyone know if the GSXR 750 sprocket will fit the the GSXR1100 wheel? I'm on a TIGHT budget and every penny counts (and I'm super cheap) so I want save every penny I can since I need to buy a new chain and those babies aren't cheap. The 750 sprockets are cheaper than the 1100. Why? Heck if I know!!!
I don't know, but I know how you can check...
Sprocket Specialists has a web site where you can check if the sprocket part numbers match.
oldktmdude
  This is a good reference source for anyone wanting to cross reference sprocket compatibility  http://www.jtsprockets.com  Pete.  :i_am_so_happy:
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
chiz
Hi
I got fed up looking for one so I got one made from alloy cost me 75 cents a tooth If I find a source for steel I will change it.
Chiz
A 1992 GSXR750 Sunstar or JT sprocket in any tooth number will work on a 1992 GSXR1100 sprocket carrier.
The sprocket carriers for the 1992 GSXR1100 and GSXR750 are the same.
http://www.partzilla.com/parts/detail/suzuki/SP-64611-40C00.html
Here is a 38t sprocket that will work.
http://www.ebay.com/itm/Sunstar-Suzuki-GSXR1100-GS1100-GS550-GS750-RF900-Bandit-Steel-Rear-Sprocket-38T-/191472791792?pt=Motorcycles_Parts_Accessories&fits=Model%3AGSXR750&hash=item2c94aaf0f0&vxp=mtr
IMO cancel the order for the alloy sprocket. FJ's eat them for lunch.
Quote from: chiz on January 10, 2015, 08:12:39 PM
Hi
Chiz
What alloy..... If aluminum then it might be short lived..... The FJ eats chains, and will eat sprockets faster when not steel. Unless you only ride it to church on Sundays and obey all traffic laws....
chiz
Quote from: FJmonkey on January 10, 2015, 10:56:12 PM
Hi
Chiz
Tanks for the tip on that sprocket.....Dint find that the ally sprocket is a issue as you describe, Unlubed I can see that it would likely melt. But the maker said keep it well lubed and it will last so far so good.
Chiz
Quote from: chiz on January 11, 2015, 09:27:42 AM
Chiz
Try to find the teeth on this Aluminum sprocket installed on an FJ....
http://www.fjowners.com/index.php?topic=1817.msg14409#msg14409
More than just a tip, it is strong advise. I am sure you can get it to last longer if you can find it with a Hard Anodize finish. But then the cost might equal a steel sprocket.
I got my 38T '92 750 sprocket from Johnson & Woods shop near by. They are an old school shop and seem to know all the players in MC parts. They can tell you if the 750 sprocket will also fit the 1100 wheel.
http://www.yelp.com/biz/johnson-and-wood-north-hollywood
If you use the alloy sprocket, please post on its endurance once a month, if it lasts that long....
Best of luck...
chiz
Is that some kind of Hybrid belt drive?? Look I'm 61  sometimes commute to work . I should be retired and go for a bit of a buzz around the mountain top occasionally put about 2000 on this summer ... sprocket still looks new.
Chiz
Derek Young
He's from Canada Mark. We don't ride like you Americans...
Derek
1986 FJ1200 (R.I.P.)
Nanaimo, British Columbia
Bill_Rockoff
Quote from: FJmonkey on January 11, 2015, 10:08:53 AMTry to find the teeth on this Aluminum sprocket installed on an FJ....
Better yet, try to find the FJ in that photo.
That's Kavin's FZ1.  He was riding that way with a passenger.  I still couldn't keep up.
I generally get 20,000+ miles out of a chain and a set of sprockets.  I can't remember if my rear sprocket is alloy or steel, that's how long I go between adjustments.
If your FJ (or FZ1, for that matter) is "eating" sprockets, you have other problems:
- You adjusted your chain too tight
- You adjusted your rear wheel unevenly from one side to the other, and it isn't pointed straight ahead but is aimed off to one side
- Whoever did your machine work on the wheel swap didn't get the spacing quite right, and your wheel sprocket is not in the same plane as your countershaft sprocket
- You tried to save money by buying an off-brand chain or sprockets
- You tried to save money by replacing only one or two of the three components last time (countershaft sprocket, rear sprocket, chain) and the worn-out part you left in place is rapidly wearing out the new parts you just bought
Motorheaddad
Thanks Fred. I picked that sprocket up. Accepted my offer of $20. Woohoo!!! I like being cheap!!!
