Rear Caliper Replacement
Started by wildfire, November 13, 2014, 01:52:52 PM
wildfire
Well I just discovered that one of my rear brake caliper pistons is rusted in place and will not move outwards. I had this problem on a different bike and was able to use compressed air to free it but I dont have access to compressed air anymore.
My FJ is a 92 . I am thinking of just replacing the caliper with a used one from Ebay.  Does anyone know what other years will fit or if you have one for sale for a 92 that is in good condition and pistons move freely let me know.
1992 FJ1200
I have a spare rear brake caliper that came off of my 89' that I don't need.
Also, the rear calipers are the same for the entire production run of the FJ1100/1200
http://www.partzilla.com/parts/detail/yamaha/YP-31A-W0057-00-00.html
wildfire
I noticed online that some rear calipers have 1 bleed valve and others have 2. Mine has two
1992 FJ1200
MOTOMYSZOR
Just connect calliper to brake hose,  block good one piston with anything (for me was enough my hand) and ask someone to pressing down brake pedal until piston will pop out .
In mine calliper was enough to clean everything out and put some red grease to fix problem.
wildfire
Quote from: MOTOMYSZOR on November 13, 2014, 03:28:06 PM
Already tried that. Wouldnt budge.
1992 FJ1200
scotiafj
Quote from: wildfire on November 13, 2014, 01:52:52 PM
try a car brake piston rewind tool ... looks a bit like a G clamp but has longer jaws that you put into the caliper between the pads and just wind the pistons back into the caliper ...then you can remove it and pump the rear brake pedal and see if the pistons move back out ...
Tom I also have a rear caliper off a 1990 that you are welcome to if you can't get the piston out.  You could remove the caliper and take it up to any shop that has compressed air and have then or you blow it out.
wildfire
Quote from: movenon on November 13, 2014, 05:53:37 PM
Thanks for the offer. I will try a shop tomorrow and hope the piston is not badly rusted or pitted.
1992 FJ1200
Quote from: wildfire on November 13, 2014, 06:31:21 PM
Replacement pistons as well as the rebuild kit are available.
Brake Caliper Piston #1
Brake Caliper Kit #1
Here is the rear caliper that I have. It worked with no issues when I removed it from my 89'.
If you want it. $15.00 should cover shipping.
Earl Svorks
  Did you ever wonder why bleed screws are shaped very much like grease fittings ?
Use your imagination, and your grease gun.
FJ1100mjk
Quote from: Earl Svorks on November 16, 2014, 12:36:02 PM
Cryptic. Me likey.
Iron Balls #00002175
www.ironballs.com
wildfire
That might have worked assuming I had a grease gun but I doubt it would  as it was seized . But 65psi and $5 as a thank you took it out. Will need to replace it as the pitting was so bad.
1992 FJ1200
