Oil leak into pick up coil area
Started by Mike 86 in San Dimas, November 08, 2014, 03:26:07 PM
I have a minor oil leak from pick up coil. Anyone familiar with a fix for this? Crankshaft seal?
Quote from: Mike 86 in San Dimas on November 08, 2014, 03:26:07 PM
Yep, crank seal. Remove rotor,carefully pry out old seal and install new.
I have them in stock.
Randy
Thanks Randy! I was not sure if it replaced that easly.
Quote from: Mike 86 in San Dimas on November 08, 2014, 03:54:22 PM
It can be difficult to remove the original as it has the external lip/ring around the outside of the seal holding it in the case.
You have to be careful not to damage the crank or case sealing surfaces.
Randy  - RPM
Ok what's he trick in removing the bolt that secures the pick up coil rotor. My manual just says to remove it. Do I secure plate with a large crescent wrench then use  socket to remove the bolt. I did this but is did not budge and I did not want to force anything...yet. Help m before I break something. I searched file to no avail. Sorry I'm sooo needy.
Ps went to the MC show  in Long Beach, Ca. yesterday. Maybe my best fix is buying a new bike. After this re-pair I will have to.  :biggrin:
How did you keep the crankshaft from turning?
Yeah, like Pat said...an air impact wrench will make short work of that.
If you don't happen to have one, you can put the bike in gear, throw a tuba-four into the spokes of the rear wheel and go at it gently.  Should give you what you need to break that loose.  Heck, that whole drive line can handle the torque of the motor, it should be able to handle the 32 ft-lbs of torque to remove that bolt.
I use a pneumatic impact gun to remove the bolt. I have heard of guys putting the transmission in gear and wedge a 2x4 through the wheel to keep it from rotating.
The impact is much easier.
Nike, ride to my house for beer and fixer up day. I can also install that Avon front tire if you are due for swap.
Thanks Mark, Might be too late for that. Using the impact wrench made remove the bolt a laugh. But I'm having real trouble now. The old seal is not cooperating I think  they use Yamabond  :biggrin:. It is just tearing apart as I try to remove it. This a real drag now. I think I was better off living with my oil leak, but I am at point of new return. Any pointers appreciated. rickin frackin rockin #!%$. :mad:
[/quote]
Randy  - RPM
[/quote]
Do I need to remove the external lip/ring? I think see can see it in there.
retraction what I think I see is internal to the seal. Enough frustration for now. A look at the Knocker post and then chill. :flag_of_truce:
Quote from: Mike 86 in San Dimas on November 18, 2014, 08:57:57 PM
What time can I show up tomorrow and help you out? The earlier the better, I owe the wife a nice dinner so I need to be home by 4ish... I can also bring over the Avon front tire I promised you...
Grab one of these seal pullers.. will make your life just a little easier..
http://www.lislecorp.com/divisions/products/?product=365
