Carb clean '86 F
Started by JohanH, September 24, 2014, 07:12:06 AM
JohanH
 :dash1: Ok, as I thought. Removed carbs today. Carbs not up to standard. previous owner has broken of the legs on two of the carbs where hinge pin goes in for float level. Repaired very badly and as i removed the last float it broke off!!!!! Now it to either repair or look for a replacement carb body.
Bummer.
Send Randy @ RPM a e-mail, he might have a couple of carb bodies for you. They are cylinder specific.
Quote from: JohanH on September 24, 2014, 07:12:06 AM
Carb float post repair information.  This might help if your in a jam and can't economically find a lower body. At least it is something to look at.  :good2:
http://www.xs11.com/forum/showthread.php?t=27137
Wow, that is a lot of work, but required if both posts are broken off.
Here is the solution I use and have been using for years...
I have never had a problem with this repair.
jscgdunn
Great fix Randy,...love it.  Baling wire and binder twine can fix almost anything.  Where you say your farm was located?
Jeff
90 FJ 1200 (Son # 2), Stock
Quote from: jscgdunn on September 24, 2014, 01:49:54 PM
Jeff
We are in the "Cowboy Capitol of the World" of Oakdale, Ca. USA
Actually I went high tech a long time ago...that is .035 stainless steel safety wire; that way it doesn't rust in the carb.
JohanH
Quote from: racerrad8 on September 24, 2014, 01:28:03 PM
Thx Randy , that looks good. Unfortunately mine broke off about a two thirds down. Will load some pix tomorrow.
Johan
JPaganel
The really nice fix involves a mill - you mill down the broken post, drill a hole, thread it, and screw in a post.
Know any machinists?
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
JohanH
Quote from: JPaganel on September 24, 2014, 03:37:57 PM
Think I know what to do. >Drill pilot hole in body as well as post. Insert a dowel coated in pratley steel as well as building up the post a bit with it.
Quote from: JohanH on September 25, 2014, 12:31:01 PM
I don't think pratley steel will hold up.  Any deterioration or bits off it will plug your jets I am afraid.   This is not an FJ carb but you could (?) do a variation of this theme.  Grind both post's down.  Make a similar fitting it will become the hold down for the needle and seat. ?? Some work but doable.
http://goldwingdocs.com/forum/viewtopic.php?f=3&t=11557
JohanH
Quote from: movenon on September 25, 2014, 04:23:42 PM
Thx , that looks like a solution. Will see what I can do tonight. When I check compression on the motor, does it make a difference if the carbs are off.
oldktmdude
Quote from: JohanH on September 26, 2014, 01:00:46 AM
No, having them off just means that you don't have to hold the throttle open.  Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
JohanH
Ok, here is the broken off  post and some gaskets i made.
They beat the crap out of that one.  Is that the only carb with a broken post ? And which carb is it ? From left to right 1,2,3 or 4 ?  They can be micro welded also but I get the impression it costs 50 -80.00 U.S. to do plus there is shipping.
jscgdunn
