Connector question
Started by Country Joe, September 15, 2014, 08:00:08 PM
Country Joe
Has anyone found a source for the wiring connectors used on the FJ? Specifically, I need the connector that is on the front turn signal pigtail. I can cut the connector off of the stock turn signal, but I'd rather not if I can avoid it. I guess I can check Ebay for some turn signals. Probably wouldn't have to be just for an FJ...
1993 FJ 1200
FJ1100mjk
Iron Balls #00002175
www.ironballs.com
Joe,
there's is typically a locking tab that holds the lead in the connector body.  Depress that tab and you should be able to release the lead from the connector.  You might be able to insert the leads into a new connector body.
Country Joe
I appreciate those links! Looks like Vintage Connections has the 3 conductor flat connector I need. And Hooligan, thanks for pointing out that the pins can be swapped over to a new connector. I have a bad habit of cutting first and thinking later. I just want to get these mirrors/turn signals wired up with a minimal amount of butchery, so when I go back to stock, it will be fairly simple.
1993 FJ 1200
I have used Molex connectors as replacement or as a new connector. Your local Radio Shack stocks them. They come in a few sizes, 4 pin, 6 pin, 9 pin and 12 pin.
I used a 4 pin connector for the Oil Temp gauge that I installed. The one thing to pay attention to is that a special crimper is required, but not necessary for a proper crimp. I own such a tool.
Photo of the connector with pinned wires and the Molex crimper.
Photo of a crimped pin.
eBay listing for a Molex crimper
http://www.ebay.com/itm/Molex-64016-0035-Crimping-Tool-for-Molex-Connectors-14-16-18-22-NIB-/380998760435?hash=item58b54bb7f3
Country Joe
Fred,
I have the crimper and both male and female pins for some Hitachi connectors I used on my Goldwing. I probably actually, for once have everything I need to start a project.  :wacko3: finishing it is another thing...
1993 FJ 1200
Quote from: Country Joe on September 15, 2014, 08:00:08 PMHas anyone found a source for the wiring connectors used on the FJ? Specifically, I need the connector that is on the front turn signal pigtail. I can cut the connector off of the stock turn signal, but I'd rather not if I can avoid it. I guess I can check Ebay for some turn signals. Probably wouldn't have to be just for an FJ...
Joe,
Here are two more suppliers, for old bike connectors.  Let us know who had the right stuff for you.
http://www.oregonmotorcycleparts.com/connectors.html
http://www.electrosport.com/accessories/connectors-and-wiring.html
jscgdunn
90 FJ 1200 (Son # 2), Stock
