Calling all 84/85 owners
Started by racerrad8, September 10, 2014, 01:39:00 PM
I need some information from all of you 84/85 FJ1100 owners. A customer bought a set of Vibranators recently and the customer determined his bars were filled with what he believes as aluminum and the damper portion of the Vibranator would not fit.
If possible, I need all of the 84/85 owners to check their handlebars to see if they are filled with a material such as aluminum or lead like these are:
You can either reply to this post or send me an email; randy@rpmracingca.com
Thank you, Randy - RPM
Maticuno
Just checked my '84.  Hollow all the way through.  No filled or plugged insides.
"The mountains are calling and I must go." - John Muir
FJ1100mjk
Quote from: racerrad8 on September 10, 2014, 01:39:00 PM
You should extend the years to 1987. Same handlebars used '84 through '87.
Iron Balls #00002175
www.ironballs.com
Quote from: FJ1100mjk on September 10, 2014, 02:04:04 PM
Okay, everyone up to 87.
My curiosity might be the fact Yamaha could have made some that were filled in 84 & 85 but went away from it in the later years, even though the part numbers are all the same through those years.
I can say this much, of my five 84-86 FJ's none of them are filled, so that is why I am asking.
I need some information from all of you 84/85 FJ1100 owners. A customer bought a set of Vibranators recently and the customer determined his bars were filled with what he believes as aluminum and the damper portion of the Vibranator would not fit.  If possible, I need all of the 84/85 owners to check their handlebars to see if they are filled with a material such as aluminum or lead   You can either reply to this post or send me an email; randy@rpmracingca.com
Randy,
I installed Vibranators in my 1985 FJ1100 with no problems, so the bars on mine were hollow.
Hollow here.
In the '80s, to reduce vibration, it was a common practice to fill the hollow space up with ball bearings or lead shot, also to cut down a "bar snake" into 2 pieces and put them in each bar.
What this fellow has is some sort of aftermarket fix for bar vibrations. Certainly not stock.
JMR
Quote from: Pat Conlon on September 10, 2014, 02:52:54 PM
Hollow here.
The regular bar snake wouldn't really work on the FJ bars Pat as it needs 2 open ends so you can pull it through. That being said you can use the liquid Bar Snake. I went that route but it didn't do really anything in regard to reducing vibration. The Vibranator system made a noticeable difference. :good:
Fj.itis
84 model here all the way from aus, hollow all the way through!
oldktmdude
   My Aussie delivered '85 is also hollow. Sounds like the work of a PO to me!   :biggrin:   Pete.
1985 FJ1100 x2 (1 sold)
2009 TDM 900
1979 Kawasaki Z650 (sold)
2001 KTM 520 exc (sold)
2004 GasGas Ec300
1981 Honda CB 900 F (sold)
fj johnnie
 Mine are hollow as well. Both 84's.
Fj.itis
I reckon someones filled it up with lead, easy enough to do and easy enough to drill out.
I already know my bars are as hollow as my head... Move on, nothing to see here....
JoBrCo
My '85 California FJ1100NC has hollow bars.
FJ Forever!  :drinks:
JoBrCo
1985 FJ1100NC
"To 'truly' see the man in the mirror, the only way for the image to be clear, as the man then 'truly' grows" --JoBrCo--
'I only know that I know nothing' --Socrates--
Quote from: FJmonkey on September 10, 2014, 09:32:08 PM
I've sometimes picked up a subtle whistling sound when you ride.  This may explain that.   :biggrin:
charleygofast
1984 Yamaha FJ 1100
1981 Yamaha XS 650
1985 Suzuki SP 600        2015 Kawasaki KLR 650
