Hepco & Becker FJ1100 Installation Photos
Started by Karlsefni, September 04, 2014, 12:56:29 AM
Karlsefni
Does anyone have close up photos of the Hepco & Becker racks installed on their FJ1100.
I have the set and the Instructions (Google translated) and they leave a lot to be desired, if someone with the racks installed could post some close up photos of the connection points that would be helpful.
I would settle for FJ1200 Photos as well.
Current         Past
'84 FJ1100    '85 FJ1100
                    '92 Virago XV1100
                    '82 Maxim XJ650
My Hepco & Becker frame is from a 1993 1200 that is used on a 1989 1200. Your mount points may be different on the 1100.
Here are a few photos.
The upper circle has a Hepco mount point where the small plastic fairing strip bolts to the sub frame.
The lower circle has the Hepco mount point to the passenger foot peg, or exhaust mount.
The 'U' shaped bracket mounts to the OEM turn signal bracket mount
<a href="http://s119.photobucket.com/user/aviationfred/media/IMAG0760_zpsdf684e1c.jpg.html" target="_blank"><img src="http://i119.photobucket.com/albums/o145/aviationfred/IMAG0760_zpsdf684e1c.jpg" border="0" alt=" photo IMAG0760_zpsdf684e1c.jpg"/></a>
The OEM tag bracket must be removed from the fender and the tag mounts to the Hepco rear cross member.
Karlsefni
Fred;
Thanks for the photos, that helps get me going in the right direction.
Terry
Current         Past
                    '92 Virago XV1100
                    '82 Maxim XJ650
