Foam rubber for body panels
Started by shockeymon, August 04, 2014, 04:16:24 AM
shockeymon
Foam rubber on inside of body panels dry rotted & falling apart. Does a replacement need to be heat resistant or fire proof or can I use any foam? I know some of the fabric stores carry foam rubber but any other suggestions appreciated
1989 FJ 1200
Kawasaki KZ750 L3
FJ1100mjk
I found some foam at work, and used the footprints of the old adhesive on the insides of the side panels as templates to cut new foam pieces, then used spray contact cement to set/fix them in-place.
If you can't find foam handy at work or around the house, one of these may work for you from a nearby home improvement store. ..
http://www.menards.com/main/doors-windows/weather-stripping/wj-dennis-air-conditioner-seal-open-cell-poly-foam-weatherstrip/p-1914339-c-3624.htm
http://www.menards.com/main/doors-windows/weather-stripping/wj-dennis-air-conditioner-seal-open-cell-poly-foam-weatherstrip/p-1914376-c-3624.htm
Here's a link to the adhesive I used...
http://www.homedepot.com/p/3M-Super-77-16-75-fl-oz-Multipurpose-Spray-Adhesive-77-24/100067550
Iron Balls #00002175
www.ironballs.com
the fan
http://www.mcmaster.com/#standard-foam-thermal-insulation/=t4tfb2
Available adhesive backed, good for up to 400 degrees and great for sound/Vibration damping.
Price per foot is not too bad. I have used this on projects in the past with good results.
McMaster has tons of other options for jobs like these.
shockeymon
Thanks already have the adhesive. I assume heat not a major issue.
1989 FJ 1200
Kawasaki KZ750 L3
WIFJ1287
I found the perfect stuff at True value hardware in the weather striping area..trimmed it to fit.
Spray glue..
Its holding up well its been about 4 years now..
