new noise
Started by lyonsee, July 13, 2014, 06:57:27 AM
lyonsee
How do I get my fj to run without the fairing ,a noise has started comes in between 70-100mph not sure if its mechanical or body panels.
So some elimination is order.
Quote from: lyonsee on July 13, 2014, 06:57:27 AM
Put the instrument cluster back on and plug it in. If your bike is a late model one it is very likely the noise you are chasing is vibration caused by seized engine mounts, that's about the speed it kicks in.
These bikes do not commonly have any engine noises that behave as you describe.
I can't see what model bike you have from your previous posts.
Quote from: lyonsee on July 13, 2014, 06:57:27 AMHow do I get my fj to run without the fairing ,a noise has started comes in between 70-100mph not sure if its mechanical or body panels.  So some elimination is order.
Lyonsee,
Elimination of one possibility: Disconnect the speedometer cable from the front wheel, and tie the loose end up as high as the speedometer (to avoid losing the center shaft of the cable).  If that fixes the problem, lubricate the center shaft or replace the speedometer cable.  If the center shaft is in bad shape, replace the speedometer cable.  Sometimes, the speedometer itself gets noisy, and even a new cable will not fix it.  These instruments can be repaired, but it may be easier to replace it with a good used part.
turbocamino
Also...'some' noises are common/normal for an FJ.....if you can state what the noise sounds like or area its from...that may be a help too.
