Fuel pump dead?
Started by Vsekvsek, July 07, 2014, 05:53:47 PM
Vsekvsek
Go to start bike today and no clicking noise and not even a click when i try and start it. Suggestions?
89 fj
09 wr300 husqvarna
Check the fuse?
More information is helpful.
Does the headlight and instrument gauges light up when you turn the ignition key on?
If they do not....30 amp main fuse, or completely dead battery.
Vsekvsek
Yeah headlights and lights all come on. Its a fairly new bat
89 fj
09 wr300 husqvarna
When you tried to start it, did it fire up ?  They will run for quiet a while with just the fuel in the bowls. Run/stop switch in run ? As Pat said not enough information. If the bowls are full and under pressure you will not hear any clicking. There is also a fuel pump relay in the system with associated connectors.
More information please, I know it can be frustrating.
Vsekvsek
holy bajesus-I had flipped the on off switch to off(I never touch it and always just leave it on) God gawd it was the obvious and I completely overlooked it and went for the hard stuff and assumed the worst first :dash2:
89 fj
09 wr300 husqvarna
Glad it was an easy fix.  :good2:
novaraptor
I don't know about everyone, but if you ride long enough, you will eventually do this at least once. Or, you'll have a child or a friend who will do it for you..
1990 FJ1200
The other scenario is pulling up to a rest stop/refuel, kill the motor with the kill switch, then forget to turn the ignition off and drain the battery.
